Main > Everything Else
Need Advice/help setting up Network
<< < (2/2)
BobA:
Directional antennas will also make the system much less susceptible to noise and interference.  At minimum a omnidirectional gain type antenna will give a better signal but a directional antenna is best in ptp applications.
protokatie:
--- Quote from: BobA on February 01, 2010, 04:53:19 pm ---Directional antennas will also make the system much less susceptible to noise and interference.  At minimum a omnidirectional gain type antenna will give a better signal but a directional antenna is best in ptp applications.
+1
Except that we all know that some DB will come around and try to "improve" the connection by moving ---steaming pile of meadow muffin---. This is why a good omni antenna might be the best practise. Besides, from the sounds of the OP it is a minimal distance.
Navigation
[0] Message Index
[*] Previous page
Go to full version
