Author Topic: Think I made a boo-boo  (Read 1478 times)
MLew
  • Last login:May 10, 2018, 08:38:25 am
« on: January 17, 2010, 10:17:17 pm »
So I replaced my monitor, it works great, but the two mains input wires in the cabinet dont have a connector on them to connect to the input on the monitor(they are just exposed wire)
Right, so as a quick fix, I put the wires in the respective slots on the monitor chassis to hold them in so I could temporarily play the game.  Well, while adjusting the monitor, the wires came loose and touched each other. There was a small spark from where the exposed wires touched and now nothing works.
The moniotr, jamma, speakers, nothing powers up. I am no electronics expert, can someone please tell me what I did?! ...and possibly how to fix it!
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
Re: Think I made a boo-boo
« Reply #1 on: January 17, 2010, 10:37:42 pm »
see if you can see a buss fuse and check that
MLew
« Reply #2 on: January 17, 2010, 11:08:37 pm »
where would i look for that?
MLew
« Reply #3 on: January 18, 2010, 08:07:27 am »
Is it on the isolation transformer?
  • Last login:Today at 08:24:26 am
« Reply #4 on: January 18, 2010, 09:53:34 am »
check the breaker in the house? its gotta be a breaker or a fuse unless you flat out killed everything.
An ounce of prevention is worth a pound of cure.
BobA
  • What Me Worry?
« Reply #5 on: January 18, 2010, 09:59:22 am »
Look for the fuse in an inline fuse holder on the AC wiring or maybe a block fuse holder.
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
« Reply #6 on: January 18, 2010, 11:46:04 am »
It's a fuse... i'm about 99.9% sure of it.  I've done it myself...
MLew
« Reply #7 on: January 18, 2010, 01:02:31 pm »
well, I found a 3A 250V fuse blown....I'm guessing thats the culprit.  I will post if it worked or not.  Thanks everyone for your help!
MLew
« Reply #8 on: January 19, 2010, 04:58:44 pm »
Bingo! Replaced the fuse, and she powered right up! Thank you all for the input!  :applaud:
here is a pic of the fuse I changed
