Main > Project Announcements
First Arcade Project - MAME Cab
Pages: << < (2/3) > >>
Don:
Been awhile but have done a good bit more!
After a lot of scraping with a razor and soapy water... clean glass!!  ;D
In order to make the bezel sit snugly behind the control panel, I had to add an extra 1cm to the back of the top panel and trim it to an angle. I did this with wood filler, a knife and a lot of sanding!
I then applied the vinyl overlay to the control panel and cut out holes for the buttons and joystick bolts.
The cabinet is now finally inside, cleaned (it was verrry dirty) and paited!  :)
Next... installing control panel, bezel, marquee and t-moulding!
falcon NL:
Looks almost brandnew! Im looking forward to see what kind of artwork you going to use!
Don:
Already have my artwork done out, just need to print it!
Posted it in this thread: :)
http://forum.arcadecontrols.com/index.php?topic=102695.0
Don:
Fitted in monitor shelf, measured to rest the TV at the correct angle.
Control panel all wired up and installed!
Looking good!
Don:
Bezel and marquee installed! Masked off tv behind bezel using card painted with black gloss.
Next: T-moulding and coin lights!
Go to full version
