Author Topic: help!!!!!!!!!!!!! anyone living in the east hertfordshire area?  (Read 1285 times)
higgo60
  • Last login:May 19, 2016, 12:42:47 pm
« on: January 10, 2010, 03:03:52 pm »
hi everyone, anyone living in the east hertfordshire area. thats would be able to give me some help with my machine. my name is paul higgins and my mobile number is 07843441187 im in desperate need to get my pc build arcade unit working again after it started playing up. i appreciate any help by somebody coming to where i am, i will pay you well for your time....... thanks
grantspain
  • Last login:Today at 12:22:48 pm
Re: help!!!!!!!!!!!!! anyone living in the east hertfordshire area?
« Reply #1 on: January 10, 2010, 03:39:07 pm »
whats the actual problem?
I am down in kent but its not a million miles away
higgo60
« Reply #2 on: January 10, 2010, 04:04:47 pm »
hi thanks for coming back, well i have been using mame gui with mamewah and changed over to maximus arcade setup which i have been using for about six months. my machine i have had for about a year which is a sega fighting viper cabinet with a pc unit inside it started playing up a couple of months ago and i havent had the chance to try do anything about it. when i switch it on its saying there is a rolling message that says system error or corrupt which i can except is probably a hard drive problem and i need to change, since then i have tried to even get it started like it use to and im not much joy and i need to get it sorted if possible..
grantspain
« Reply #3 on: January 10, 2010, 04:08:45 pm »
probably sort this on forum tbh,
so atm you have replaced the hdd but its still not working?
higgo60
« Reply #4 on: January 10, 2010, 04:46:57 pm »
well i had changed it but since then it hasnt worked but i did put the sata hard drive into another system and installed windows xp and mame gui etc and then installed it back into the machine but now im not getting any response from the motherboard and im thinking it might be the power supply which i have bought another one of as well.
grantspain
« Reply #5 on: January 10, 2010, 04:53:49 pm »
yeah sounds like psu,did you reinstall 15k soft or do you use a avga card or jpac btw?
higgo60
« Reply #6 on: January 11, 2010, 06:47:37 am »
Well I never reinstalled the 15htz software to convert to the monitor but the reason I done this is because I bought a arcade VGA card from ultimarc and I thought I wouldn't need to. Would it possible to actually speak to you instead of emails?
higgo60
« Reply #7 on: January 11, 2010, 03:45:34 pm »
also the power supply i changed from a 370 watt to a 500 watt supply, would that do anything to my problem?
higgo60
« Reply #8 on: January 12, 2010, 11:13:59 am »
Hello mate, could you still give us some advice because your the only person willing to help cheers!!!
