Main > Main Forum
Ipac4 issue?
Pages: << < (2/2)
Bobulus:
I mean, I can't think of anything that could happen in the BIOS that would make it behave this way, I'm just trying to cover all the bases.
Lo_Wire:
Hmmm, thanks for your help, Im hoping the ultimarc guy may chime in next time he's online.
Its a real pain in the ass! :-[
worked first time, maybe I changed something in stickykeys, was trying to play and all these annoying messages kept popping up every few minutes - because of button presses.
Lo_Wire:
Would using a ps/2 to usb adaptor work?
AndyWarne:
If you have a keyboard plugged into the pass-through connector on the I-PAC you could try rebooting without this connected and see if the I-PAC still works. Also try another keyboard.
If the I-PAC is very old, (ie around the time XP first came out) there is another fix, best drop me an email if this is the case.
Andy
Lo_Wire:
Andy helped me out with this one :applaud:, was a problem with my computer not the Ipac4,
switching to a USB/Ps2 cable solved the problem and now works perfectly!
Pages: << < (2/2)
Go to full version
