Main > Everything Else
What did Sandy Claws bring you?
<< < (8/14) > >>
Ginsu Victim:
--- Quote from: MaineEvent on January 05, 2010, 01:29:22 am ---But no Lasik huh...good thing you got your priorities straight :applaud:
Lasik would've only cost about $3500 MORE than all that.
ChadTower:
I got my son a black wiimote and nunchuk... then picked up a Wiimote charging station... and of course, the station requires you to swap out the battery covers on all Wiimotes... and the replacement covers are all white.
 :P
Ginsu Victim:
But once you put the sleeve on, you don't see the white cover anyway.
ChadTower:
Can't use the sleeve with the charger.  Not unless you cut a hole in the sleeve.  The new battery cover is for contacts on the battery for the charger - and you have to take the WiiMotion Plus off as well because the charger doesn't fit that either.  I took the sleeves off of all of our Wiimotes a long time ago because we were swapping out batteries so often they were more of a pain than a feature.
Vanguard:
I recently saw an inductive charger for the Wii.   You just lay the Wiimotes on a pad and they charge.  No issues with the condom or motion plus.  Same things been around for cellphones for a bit too.
Not sure what the battery technology is though.   Been meaning to look into it.   The 4 station pad was around $50 with the battery packs.
If they are LIPO or LION batteries (in other words not nickle based), they seem like an awesome solution.   When my current charging station (or batteries) die, I'll probably get one.  We've already had one battery pack die.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
