Main > Everything Else
Another $100 streaming media player, this time from Asus
<< < (8/10) > >>
protokatie:
So chad, do you have Hardwood or Plywood? Either way it seems like it would be hard to pee... (Just try to visualize what "plywood" would be... Luckily I dont have that problem...)   >:D
Edgedamage:
--- Quote from: shmokes on December 09, 2009, 08:37:29 pm ---Uncompressed blu-ray rips???  That's gotta average like 25 GB per movie.  Just how much hard drive space do you have?
I only have 4tb networked storage so far, I use a 500gb hdd in a eSATA / USB dock. I am just a sata whore but to be honest USB will work also. Plus my drive gets the shutdown command when using eSATA with the asus.
ChadTower:
--- Quote from: protokatie on December 11, 2009, 11:54:28 pm ---So chad, do you have Hardwood or Plywood? Either way it seems like it would be hard to pee... (Just try to visualize what "plywood" would be... Luckily I dont have that problem...)   >:D
Depends on how cold it the room is, I suppose.
shmokes:
I keep plugging this Boxee Box, but I can't help it.  It keeps getting better.  Check out the remote.  Navigation on one side, Qwerty on the other.
boykster:
Uncompressed BD rips are anywhere from 12 to 30+ gigs per movie - its a lot of space but its worth it if you have a display that supports it and can swing the storage.
That Acer box thats linked will run XBMC, but the UI might run slow if you run a heavy skin (ie Aeon).  Video playback if you run the linux version will be flaweless and smooth using gpu VDAPU, but the windoze version doesn't (yet) support gpu playback.
XBMC rocks - I just bought 2 Asrock 330 ION PC's to replace my aging HTPC's running DVDLobby / ZoomPlayer and it effing rocks.
Oh, and that Boxee box is effing akward!  Um, why?  I don't care how small it is, but um, you could try to make it "fit", no?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
