Author Topic: How do you guys mount your lcd monitors ?  (Read 10735 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: December 02, 2009, 05:30:40 am »
Hi guys. I bought a nice 21.5 inch lcd monitor for my cab. Does anyone know any good ways to mount it in the cab ?  I will buy a mount kit if i need to but i thought someone might have a better idea. Thanks
This is the monitor i bought if it helps.
http://www.tigerdirect.com/applications/SearchTools/item-Details.asp?EdpNo=4802822
ammitz
  • Last login:April 25, 2017, 07:22:09 am
Re: How do you guys mount your lcd monitors ?
« Reply #1 on: December 02, 2009, 06:03:34 am »
I mounted my 19 inch monitor on a MDF board 12 mm thick and 55X15cm. Then I drilled four holes, making a square like the VESA mount on the back of my LCD screen.
Bougth some longer screws to hold the screen in the home made mount, and I fixed the MDF board to the sides with ledgers.
Really simple and cheap.
I made a very bad drawing showing what I'we done
« Last Edit: December 02, 2009, 06:08:23 am by ammitz »
Building my first bartop CAB
rlemmon
« Reply #2 on: December 02, 2009, 06:49:27 am »
Vey cool thanks !   :applaud: What size screws did you use ?
Blanka
« Reply #3 on: December 02, 2009, 10:21:38 am »
Often the foot of a LCD screen has a vesa-mount built in under the plastic case, and 1 or 2 big bolts to attach this to the foot. Use that hidden mounting plate for even easier fixing and positioning.
Blanka
« Reply #4 on: December 02, 2009, 10:23:33 am »
Excuse me, that model does not have a center attaching foot. Maybe you can find a non-working old LCD.
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #5 on: December 02, 2009, 11:01:39 am »
I bought the above mount for $10 shipped with the intention of using it for my desktop 24" monitor but didn't line up so I ended up using it for my 17" LCD monitor below for my bartop arcade cabinet.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
bkenobi
« Reply #6 on: December 02, 2009, 12:39:42 pm »
Bartop = portable, correct?  That mount will not lock the monitor onto the mount if the cab is tipped.  What precautions do you have to keep the screen from becoming dislodged during transport?
Queeg
  • Last login:January 18, 2010, 11:12:13 pm
« Reply #7 on: December 02, 2009, 01:11:23 pm »
All I did for my cab was install a shelf that the monitor would just rest upon. I have a really nice adjustable stand with about 1 ft of vertical play and about 60 degrees of rotation. This is nice for me because it allows me to experiment with viewing angles without having to commit to one. When I want to move the cab I simply unplug the two cables to the monitor and take it out through the back door.
I am running a 16:10 30" lcd.
bkenobi are you the same bkenobi on the gameEx forum? Just curious.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #8 on: December 02, 2009, 01:26:23 pm »
Some shots are taken from a bartop project i did once , the others show the adjustable mounting of a 20 inch dell tft into a table arcade.
« Last Edit: December 02, 2009, 01:39:00 pm by apfelanni »
bkenobi
« Reply #9 on: December 02, 2009, 11:28:06 pm »
Yup...
mwong168
« Reply #10 on: December 03, 2009, 12:22:16 am »
Bartop = sits on top of a bar not portable.  The only way I can see this coming off the mount is if I flipped the entire cabinet upside down.  I could put a piece of wood strapping on the inside to keep it secure but I don't really plan on moving this around too much and it sort of locks when in place on the mount.
ammitz
« Reply #11 on: December 03, 2009, 02:35:56 am »
Don't actually know. Had some lying around that fitted.
You could just measure the srews that's already used and the add the depth of the board.. Should be pretty easy.
  • Last login:December 13, 2023, 12:03:14 am
« Reply #12 on: December 03, 2009, 10:30:11 am »
I think the screws for the vesa mount on my LCD were 4 mm.
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #13 on: December 03, 2009, 05:59:17 pm »
I have a 19" Dell that I decased, and will use the vesa mounting screws on the back into a peice of wood, like above in the first example.  I will then use pocket screws to get the wood mounted in my cab.  Did basically the same on my jukebox too.
Pictures of the decased LCD for my cab -
Placed the old case, reassembled without the guts, on a coworkers desk to replace his monitor.
Picture of the same type of idea from my jukebox while building it, LCD wasn't decased for it -
severdhed
  • RIP Dinosaur Hippo
« Reply #14 on: December 04, 2009, 02:41:02 pm »
same here.
