Author Topic: jamma xx in 1 boards  (Read 1693 times)
gazz292
  • Last login:January 22, 2022, 12:00:01 pm
« on: December 01, 2009, 08:05:40 pm »
I have a golden tee 98 cab, jamma wired, going to mame it but wont be able to complete it for a while as money is tight.
so i was thinking about getting one of those xx in 1 jamma boards, and a few joysticks, adding the joys to the cp, plug the multi game jamma board in and be able to play a few games whilst i save up for the rest of the gear i need to do the mame project,
would do the cp first, and connect up just a couple of joys and the trackerball and buttons to the jamma harness, then get the bits for the pooter to run mame, and get rid of the jamma stuff.
however i've had a look at whats available on ebay, im in the uk, so not a lot really, just a few 60 in 1 boards brand new, and an old 30 in 1 board,
but they all seem to have vertical games on them, and say in the listing for vertical monitors only.
would there be any way to play the vertical games on the horizontal golden tee monitor without rotating it? not looked closely but it seems the golden tees monitor is more square than the old monitors used to be.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: jamma xx in 1 boards
« Reply #1 on: December 01, 2009, 10:00:12 pm »
Nope.
Working: Not Enough
Projects: Too Many
Progress: None
  • Last login:Today at 08:24:26 am
« Reply #2 on: December 02, 2009, 08:49:53 am »
well, you could turn your head but ,yeah, no.
gazz292
« Reply #3 on: December 02, 2009, 09:30:54 am »
Good idea that, i'll put the cab by me bed, than play vetrical games laying down...sorted  :notworthy: :)
Suppose i'd best go out and have a look at the cap properly and see if the monitor can be put in verticaly... it's an electrocoin zeon cab.
now i'm thinking about a rotating monitor.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: December 02, 2009, 09:40:30 am »
Do you really want to limit yourself to just vertical games with limited viewing and game options? If you're gonna MAME, do it properly with a PC and you can enjoy the best of all worlds. If you're going with simplicity you will be severely limiting yourself, but if you really must then search and you will find better multi-game jamma boards from the continent that cater both horizontal and vertical games on a horizontal monitor. Personally for the several hundred quid you're likely to part with, you'd be better off looking at a full PC setup.
gazz292
« Reply #5 on: December 02, 2009, 12:51:39 pm »
oh i will be doing a proper mame set up, but cant afford the pc bits for a while, so thought whilst i make the cp's i'd stick a multi game jamma board in there to use the cab, but the games on the jamma boards i want to play the most are vertical.
with they did a square monitor that could then display horizontal and vertical easily with borders to fill in the edges.
Turnarcades
    • Turnarcades
« Reply #6 on: December 02, 2009, 08:19:10 pm »
Considering you can pick up a perfect MAME PC now for well under a ton and you are interested in vertical games that don't need much processing power, it's not going to be cheaper for a multi-game JAMMA board.
bdjou
  • Last login:June 10, 2011, 12:34:22 am
« Reply #7 on: December 03, 2009, 12:46:05 am »
You could also do a multi-williams or one of those blue elf boards for horizontal games.
gazz292
« Reply #8 on: December 03, 2009, 06:37:21 pm »
well, not totaly interested in vertical games, i like horizontal ones too, just that i wanted to get a pretty decent pc in it, so would by bits and pieces, one week the mobo, few weeks later cpu and so on,
just want to be able to use the cab before i mame it totally.
been offered a loan of a 48 in 1 jamma board tho, so i am hopefully sorted,
need to see if you can get square monitors now or i'll be making a rotating monitor cab, annoying as i dumped a square screened 25 inch TV a couple of years ago that would have been perfect, used to play mame on it in me bedroom, but got rid when i got a lcd wide screen, bloomin progress.
