Main > Main Forum
Other than a juke - what could I make out of a touchscreen?
ediblegod:
--- Quote from: bkenobi on November 25, 2009, 10:41:46 am ---How do you attach these to the screen so they don't look like an aftermarket screen cover?
I used some "Fastcap" Speedtape which is pretty much a strong double sided tape. Works great!
As with small touchscreen, I'd mount it in the car as a carPC :applaud:
bkenobi:
So you just attach the edge of the screen, or is that tape transparent?
ediblegod:
Just around the border...
slapaham:
It's not exceptionally tricky to figure out ways to attach them. On my 15" I had to sand down part of the casing of the LCD monitor I applied to so that it would fit it. Just taped it around the edge of the monitor and the casing was so tight it has never moved or slipped out of place.
By the way... Encryptor - I really don't see why they would work - it's all about what system you're using it - it's USB and acts as a standard mouse so it shouldn't really matter what screen you're applying it to...
I'm attaching mine to a PSOne TFT after all... ;)
Encryptor:
--- Quote from: slapaham on November 25, 2009, 05:49:00 pm ---By the way... Encryptor - I really don't see why they would work - it's all about what system you're using it - it's USB and acts as a standard mouse so it shouldn't really matter what screen you're applying it to...
Yeah I know you're using a PS1 screen but they are square. The lcd's I am using are only 4.6" screens for one thing and they are 16:9 wide screen format so they aren't square. It might be possible but I don't think so.
Encryptor
