Main > Main Forum
What games support push pull spinner?
mytymaus007:
yeh thats a nice franken panel! he's got the right push and pull spinner get this spinner http://www.apachecontrols.com/ and this HAPP trigger http://www.happcontrols.com/joysticks/50997000.htm order it with 2 top buttons youll be set
jasonbar:
--- Quote from: mytymaus007 on November 14, 2009, 12:16:08 am ---yeh thats a nice franken panel! he's got the right push and pull spinner get this spinner http://www.apachecontrols.com/ and this HAPP trigger http://www.happcontrols.com/joysticks/50997000.htm order it with 2 top buttons youll be set
Thanks! ;D Thanks? :-\ Thanks!?!? :P
Yup, I'm happy with the Apache Push/Pull spinner (pricy, but a good product), & the Happ stick is solid too. The red Satan's Hollow case is swell & fits my cab theme well too. If only my arms were a bit longer, I'd be more comfortable reaching the farther controls...
Thanks,
-Jason
mytymaus007:
hey is that an original satan hallow case on a happ trigger . How does it fit also how to yu have the xarcade call set up when you play im assuming marbale maddness but what all the handle for
jasonbar:
It's an original Happ 2-thumb-button triggerstick & a Groovy Game Gear Satan's Hollow reproduction case.
It went together fine--I printed my own insert on photo paper & installed it behind the clear insert that came with the GGG case (after pulling the GGG sticker off & dremeling 2 holes--didn't want to drill lest I crack the plastic). This turned out to be a little too thick & a little tough to reassemble, but that was my fault. "Normal" assembly should be easy.
Yup, the X-Arcade trackball on the right side of my cabinet is for Marble Madness, Cabal (or Blood Brothers?), Rampart, and the few other games that use more than 1 trackball.
Thanks,
-Jason
mytymaus007:
Heres my Apache spinner PUsh and pull and Happ trigger works great!!
