Main > Main Forum
Anyone Try the Aim Track module with this gun ?
Pages: << < (5/5)
TeutonicDarkness:
 I finally got one of my Guncons in.
Began Immediately working on it! ( I will post pics later)
I'm using my first gun as the prototype.
 When my second gun come in I will fully document my progress!
( That is when I get my 1st gun fully functional!)
The Guncon really is a great gun for this mod.
So Far I just removed the Main Guncon board and left simply the 2 mini boards
for the buttons.
I'm also now looking into wiring up button 3 once I get a little more
info on wiring into these mini solder points on the Aimtrack!
I need to make a permanent fixture for my sensor bar and possibly do
a little trimming on the gun nose.
This gun is Very accurate already almost unbelievable!  :)
I have had the Act Labs, LCD Topguns, etc.
This is by far the best gun out Bar none! :cheers:
thatitalian:
Please please please! ;D
I would love to know how to modify it as i am planning on getting a couple of G-cons myself, but maybe the G-Con 45 (same thing, different colour).
KonkeyKong:
Anybody have an idea what this Cherry switch Randy used might be?
TeutonicDarkness:
 I rigged up a housing for my sensor bar.. did some mods to my
Aimtrack gun.
I booted up it was perfect!
Then after about 2 minutes the tracking went Haywire... ???
It will only read the top half of the screen.
So I Booted another PC and low and behold after after 2 minutes same thing.
Now I'm starting to worry That I could have fubbed up my Aimtrack
when I was soldering into the AUX pins on the board :'(
Anyone else had problems with tracking going haywire after about 2 minutes?
TeutonicDarkness:
 I have made a lens cover!
The Plastic from a CD spindle case is perfect!
Here is the homemade lens in gun:
Finished product:
Turned out ok so far if I can figure out the 3 - min tracking problem!
 More to come I'll try to document the 2nd gun as I'm doing
work; as now I know what to do!
Pages: << < (5/5)
Go to full version
