Main > Everything Else
At this price, I might be going SSD
<< < (5/7) > >>
HaRuMaN:
Hmmm...  after reading that, I want to build a Win7 SSD machine
divemaster127:
I am using windows 7 & I did some research before I took the plunge the speed improvement is unreal, i guess if the SSD dies I will be the first to find out
Cakemeister:
Windows 7 has been installed. It's pretty easy to change the directories that files go into, to point to the data drive. I'm installing applications now. The big one will be Office, haven't done that one yet. Boot speed is excellent. Noise level is excellent. There's nothing not to like so far. I need a new backup solution, however.
SavannahLion:
--- Quote from: pinballjim on November 03, 2009, 09:26:00 am ---Good god... running the OS out of RAM?  Are we back in the 386 days?
Did that back in er.... '98, '99 or so. An engineer and I jammed a server with IIRC 8GB (or was it 16GB?) of RAM, four Xeons, installed some virtualization software, "partitioned" the RAM to fake a hard drive, then installed NT. It was an interesting experience. Flew through the burn in test.
Xiaou2:
 What do you think is faster:   DDR II  ram,  or  a  SSD Flash drive?
 There is a reason they use such memory attached to the CPU.  There simply
isnt anything faster... unless they decided to integrate all that ram directly inside the CPU itself.
 The  "Hyperdrive5"   can support 8 x 8gig ddrII sticks for a total of 64 gigs of power and speed
which wont burn out in 5 yrs like a SSD will.  It will never develop bad sectors, and have to deal
with software defragment performance issues.
 It boots windows XP in 4 seconds.
http://www.hyperossystems.co.uk/
=== Full Company specs ===
Takes 8x 240 pin DDR2 DIMMS from 2GB - 8GB.
2x SATA2 interface ports.
CD ROM Drive Form Factor.
175MB/s Read rate.
145MB/s Write rate.
65,000 IOPS. Hard disks do 200-300 IOPS (File Inputs or Outputs Per Second).
10  microsecond disk access time. Mechanical disks take 5-15 milliseconds.
It finds files 500x faster than the world's fastest mechanical SAS hard disk.
No drivers needed, connects like any other SATA HDD.
Boots Windows XP in 4 seconds!
Most operations become instant!
Formats Instantly!
Never needs to be defragged. It's Random Access!
Silent Solid State Disk, no moving parts, no NAND flash to wear out!
Compact Flash card backup port in case of long power outage.
Takes any UDMA capable CF card with capacity as big as installed DDR2.
Automatically backsup to CF in the event of power loss.
Automatically restores from CF in the event of power gain.
Lithium Battery 7.4V 2400mAH. Powers unit for 2-3 hours. 500 charge/discharge cycles.
External DC adaptor port for keeping data when PC is powered off.
LED indicators for power, activity and battery charge %.
The Drive has built in ECC so it can safely take cheap non ECC DDR2 DIMMs.
Designed to take any unbuffered non ECC 400-800MHz CL5/6 240 pin DRR2 DIMMs.
Tested with Kingston, Corsair, Qimonda, G.Skill, OCZ, Mustang.
DDR2 underclocked to reduce power consumption, enhance stability and prolong life.
FCC Certified. CE Certified. VCCI Certified. BSMI Certified.
15 month RTB Warranty.
MTBF of underclocked DDR2 is several generations (a lot longer than our financial system!)
100% secure file deletion if required.
The simplest and cheapest way to get mainframe performance from your PC.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
