Author Topic: AIMTRACK installation in Guncon, need help with PCB  (Read 2860 times)
ammitz
  • Last login:April 25, 2017, 07:22:09 am
« on: October 28, 2009, 01:50:02 pm »
Have recieved my aimtrack and an a GunCon-1  :applaud:
But my experience in the electronics department is VERY limited. So my question is which wire is the common ?
This for the trigger (Marked T1 and T2 on the picture)
And the 2 buttons A and B ( Marked A1, A2 and B1,B2)
Here is a picture og the PCB
Building my first bartop CAB
bkenobi
Re: AIMTRACK installation in Guncon, need help with PCB
« Reply #1 on: October 28, 2009, 01:58:58 pm »
I don't know, but here's the USB spec.
http://pinouts.ru/Slots/USB_pinout.shtml
It depends on which way the connector attaches.  It's either A1 or B2.  My guess based on the board is B2.
RandyT
  • Last login:Today at 11:46:17 am
    • GroovyGameGear.com
« Reply #2 on: October 28, 2009, 02:01:26 pm »
I haven't been inside my original GunCons.  Are these going to connectors for wire harnesses?  IOW, what's on the other side of the board?
If it's wires, you just need to isolate the two wires per switch and skip the original board altogether.
RandyT
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #3 on: October 28, 2009, 02:03:34 pm »
I do video game room setups for anime cons and stuff using just consoles and accessories.  Sorta like an mobile arcade but assembled with old TVs and consoles.  Naturally, any light gun that gets 14hrs of non-stop use will eventually suffer from failure.  I have a Guncon 1 with a damaged composite video adaptor that's broken inside the undisassemblable PS1 plug, and another with a faulty trigger.
Would any of you guys who are getting Guncons for Aimtrak's be interested in donating me your guts so I can do repairs?
ammitz
« Reply #4 on: October 28, 2009, 02:16:06 pm »
PM me your adress and I'll mail it to you
Back to my problem.
I dont know if I was precise in my question, so I'll try once more differently.
My question is, when I want to wire the trigger using the one allready installed in Guncon1, which wire should go where.
Here is a picture of the new PCB from the aimtrack
and here is a picture og the trigger button from the Guncon1
So should T1 be connected to "com" or "trigger"?
And the same goes for button A and B Only a picture of the PCB from button A but B looks the same on the other side.
Here is an picture of the PCB from the GUNCON from the backside
« Last Edit: October 28, 2009, 02:26:10 pm by ammitz »
DJ_Izumi
« Reply #5 on: October 28, 2009, 02:26:10 pm »
I -think- I just successfully PMed you.  Lemme know if I failed. :X
RandyT
« Reply #6 on: October 28, 2009, 03:06:44 pm »
The answer here is to disregard the GunCon board entirely.  In this particular instance, the "common" is where you decide it should be.  These are simple SPST switches, which means the action is nothing more than bridging those wires you see coming from the boards.
Tie one side of each of them together and that's your common.
RandyT
ammitz
« Reply #7 on: October 28, 2009, 03:08:37 pm »
TY very much for your quick reply :)
IT WORKS ;)
I'll put up some pictures later.
« Last Edit: October 29, 2009, 05:32:13 am by ammitz »
bkenobi
« Reply #8 on: October 28, 2009, 06:04:30 pm »
My mistake.  I thought you were looking at the bottom of an AimTrak board.  Obviosly, the giant NAMCO logo should have clued me in that I was looking at your question wrong.   :banghead:
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« Reply #9 on: November 08, 2009, 03:14:12 pm »
IT WORKS ;)
 How about them pictures?   ;)
I'm going to install the Aimtrak in a guncon myself.
Well that is when my guncons arrive.
So any detail will help!
ammitz
« Reply #10 on: November 08, 2009, 04:14:50 pm »
Sorry, havn't had time for the pictures.
Can only say it was pretty easy, and my knowledge about this is pretty low. There is plenty of space inside the gun for the wiring and the camera.
