Main > Everything Else
kids and martial arts?
ChadTower:
Nobody knows how a person is going to react to getting punched in the grill until that person gets punched in the grill. There is no substituting that with anything else if your goal is capability in a real fight. That applies to fighting, contact sports, or anything else where a person has to do something that really hurts and either quit or fight back.
Chadwick:
Both of you make excellent points, and I don't disagree with either of you.
I freely admit I may have been a bit hyperbolic in my previous posts, but sweet baby Jesus in a manger... did you read some of the claims he made?
Hoopz:
--- Quote from: Chadwick on November 06, 2009, 12:01:41 pm ---did you read some of the claims he made?
Nope. Been there, done that. Same song and dance as before.
Xiaou2:
--- Quote ---And Xiaou, you need to stop thinking that anyone who disagrees with you is a bully, Nazi, or any other
Firstly, I have no problem with a person who disagrees. However, there is a
difference between a person who disagrees, and a MOB that gets together
to work their mob powers.
These BulshidoEns, do not argue rationally. They bash and burn anything,
offensively, if it does not go along with what they believe.
I can understand a group getting upset by masters saying they can control
a person with invisible energy... but the other things they try to destroy,
are not even comparable. They do not research deeply, do not perform real
world test. Do not care to try to understand and Learn something new.
Grasshopper is saying just just about exactly what Ive posted. While WC
may have limits to the training... One can always go out and Spar others,
and get that experience, as I did.
I can take any Boxer, train him in WC, and yeah... he will probably no doubt
be better at WC than a first time martial artists who only took up WC, and never
did any sparring. That said... "I" did learn WC as my first art... but I was no
pushover. I went out and sparred constantly as soon as I had a decent level of
foundation... AND, it worked.
The "argument" that WC does not work, because some lazy students dont want
to go out an put on some gloves.. is crap.
As for my claims, they are all as said. And, anyone who does the research, will
find that Im not the only one who knows about, or can do this stuff. Of course,
to really understand, you may need to march yourself to the nearest JKD or WC
school to see if one of them has someone capable to Demo on you. OR, you can
start training your Weakness of short range power... and soon see massive
improvements, as you start to develop and understand. And No, there is no
violation of physics in Fajin.
This article better explains the concept of Fajin in non-mystical terms:
http://www.martialtaichi.co.uk/articles/fajin.php
A Fajin strike is not limited to a Wrist strike as seen mostly in Chen Xiaowangs
Tai Chi demonstration. It can be added to Any strike. Punches, elbows,
finger strikes, as well as Kicks.
I can also say, that Ive fought Many good TKD artists. In fact, Ive taught
myself a lot of their style of kicking as well. TKD however, does not do much
with Low kicks.. as that is against the Sport style Sparring they do. IF
some TKD do low kicks, it would probably be a round kick.. and not a straight
stomp/stop kick, that is in WC, and some other KF styles.
ALSO, TKD (In Most places) does not train their kicks against SOLID hard
objects... such as a brick wall. They are used to kicking soft people, pine boards,
or a soft-moving kick bag.
Whats the Differences?
For example, if you go out to a parking lot.. and kick one of those 4" diameter
parking poles, a tree, or similar... its not going to give much if at all. The forces
will then be directed more inside of your own body. If you have ANY weak or
loose section, it will crumble (bend/flex) from the forces... and that will cause
a loss of conduction. Loss of conduction, will result in loss of power delivery
ability.
Conduction?! Anyone knows that a solid object is best suited to conducting
energy. It you place a block of wood in front of someones chest, hit the block..
the person will still feel/get plenty of that energy. The wood conducts very
well. However, repeat that with a block of softer rubber.. and the rubbers
material will absorb some of the forces through "flex".
If you were to hit a person, and your elbow bent a little in the process, you
effectively Lost power to deliver. Same also, is if your knee bent a little when
you made impact. And even harder to notice, is internal stuff.. such as if
part of your body is "Relaxed" when you hit. Sure, your first and arm may be
tight... but what about your mid section? Your legs? If they are not ALL
completely Linked and Solid at the exact moment of Greatest Impact forces...
there Will be self absorption losses.
A concept that you should try to remember, is that to gain max power,
you need aid of the Ground. Any force exerted against you, goes all the way
thru you, and to the ground at your feet. If you were to jump in the air, and
double palm a wall, you would be forced backwards, as there is nothing to
brace you. Forces lost. However, if you were to hit that same wall, with good
braced footing from the ground... you can maintain that Connection and
Conduction from Ground to Fist. In Tai Chi, they call this a "Ground Path".
A Path that goes from the ground to your fist, with a Solid muscular/skeletal
connection.
Now, you will say... "But Boxers already do this". Its true. Almost anyone
uses these concepts. The problem is accuracy and timing. If you are off
a hair on one aspect.. or off by a split second of time.. you can lose up to
50% power delivery. This is why most boxers do not knock each other out
with a single hit. They simply can not deliver power accurately every time,
and lose most of it due to slight problems here and there.
A boxer also does not build as much "Fast-Twitch" muscles. They are more
concerned with bulky strength instead. Fast twitch, allows the ability to
do a full body "Spasm" or "Convulsion", at speeds of hundreaths of a second.
A sneeze (exhaling, not the build up) is very similar... and have been estimated
to be as fast as 649 mph, or 290 ft/sec. 85% of the speed of sound.
A typical punch, will never reach 650 mph. However, add Fajin on to the End
of a punch... and you have effectively struck all of your mass, at over 650mph.
This kind of power is devastating. Hence the term "Explosive".. it can literally
burst internal vessels / organs. Most people skilled at this, will never draw back
more than 3 inches, use only partial power, and always use something like a
phone book in front of the target to help disperse the energy. Besides the
material being able to flex a little.. .the wide of the book is less damaging
due to the forces being less concentrated all in one small area. Also,
the fist is not allowed to go very deep into the target.. which results in more
compression of the targets internals, and thus more serious damages.
For every inch pulled back, Fajin is capable of Multiplicative damages. Instead
of a scale of 1,2,3,4,5,6,7.. its more like 1,5,25,85,500,7500.
It can be created merely from a body tense timed perfectly (at the
end of a strike)... Or in the advanced methods, can use the hips/body
rotations added to it for even more power... and finally, you can also use the
combination of simultaneous forwards footwork as well.
A person who Tries this and gets nothing more than a push, will immediately call
BS. This power is not developed overnight. It can take a few months to notice
the power level changes. And less than a year of dedicated work, you can
be lethal at close ranges.
Going back to my post about the Stomp kick... Which is a Diagonal downwards
low kick aimed mostly at the knee or shins, toe pointed outwards.. Hitting with
the bottom of the foot nearest the heel. Its more dangerous than a round
kick because its usually thrown when someone is coming directly at you. As
they plant their lead leg, that contains most of their mass on it... you have already
started to make contact with it. With that full body Fajin energy, you tense up.
Your rear leg fully grounded. The power levels will easily stop a kick, but more
so, can do ridiculous damages.
Its again, trained properly, by striking Solid objects such as thick diameter poles,
trees, etc... Keeping your Shoes on. There is no need to do barefoot training
for this. Kick at full power, slowly first.. later working on full power & full speed.
Speed in delivery, and Retraction.
A curved low kick can easily be disapted by a slight leg lift, footwork, body turns,
palm block, knee bending, etc.. The body can flex to absorb these forces decently. Not the case from a body that is moving forwards. A fighters conditioned legs can may have meat in the area which is to be struck, and or just is dense enough to accept the power levels. You can not easily condition the knee. And since you are kicking in a direction that the knee can not bend in, they
will not be able to diffuse the energy... thus full damages ensue.
Its hard to see, as its lightning fast. Its 10x faster than any MT kick, and
10x as deadly. Anyone knows that a straight line is more effecient than a circle.
It also nearly impossible to block.. unless you always keep your weight on the
rear leg. A practice that most WC styles do, as we are left with a front leg that
can instantly attack or defend with the lead leg without any "De-Weight" time.
De-Weight time? If you are resting your weight an your lead leg.. and need
to kick with it.. you have to first lean back and take the weight off it, so that you
can begin to lift it.
Bruce Lee liked to do something similar, but with the rear leg. He would stand
with a front loaded lead, and throw a rear-straight wc low kick with it. Lightning
fast stuff, and incredibly powerful.
Ive posted this rough Pic as an example of the dangers of a Stomp kick -vs-
traditional boxing Lead leg footwork. Note: The lead kick foot was not edited to
show it should be pointing slightly outwards... as it currently appears to be
almost sideways... which isnt the case. Rear knee should have a hair more
bend in there too.
shmokes:
Xiaou . . . if guy writes a novel on an arcade message board and nobody reads it, did he really write the novel? My friend, nobody . . . and I mean NOBODY read your last post . . . not all of it, anyway. I read the first few paragraphs, but I couldn't keep going.
Trust me, if a windbag like me is calling for a little brevity you have a problem. Reel it in a little. Words that are never read never convinced anyone of anything. I promise you, nobody read that whole post.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
