Author Topic: MVS 4 slot with 100 in 1 board in action HAPPy here  (Read 1314 times)
dtechlogic
  • Last login:July 09, 2010, 04:46:57 pm
« on: October 21, 2009, 01:13:10 pm »
Hi Guys,
Finally i got my MVS NEOGEO 4 slot working. I have obtain a new Board and also a 100 in 1 cartridge. Please advice on how can i get the Marquee light on top of the cabinet to work they don't turn on
Beretta
Re: MVS 4 slot with 100 in 1 board in action HAPPy here
« Reply #1 on: October 21, 2009, 01:46:19 pm »
look for screws at the top holding the plate on.
behind it will be a light of some sort.. probably florescent, it should come one when ever the game is on, so chances are the bulb is burnt out and needs replaced.. shouldn't have to do anything special to get it to come on.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 21, 2009, 01:54:09 pm »
A dedicated Neo Geo cabinet uses electroluminescent panels to light up the individual "mini-marquees". Quite frequently the panel itself goes bad or gets very weak. There is a driver board that powers those panels located in the marquee area. The cabinet should have a National Cabinet Lock Company key # C-413A to unlock the swing down retainer to access the marquee area.
dtechlogic
« Reply #3 on: October 21, 2009, 02:42:34 pm »
Actually my Locks are messed up and i don't really know where to get them. i have check home depot and they don't have them.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: October 21, 2009, 02:51:53 pm »
Here's the lock manufacturer's site:
http://compx.com/national.html
Here's the catalog. Page 12 has the standard locks and keys used on coin operated games:
http://compx.com/images/july2009-national-catalog.pdf
« Last Edit: October 21, 2009, 02:59:55 pm by Ken Layton »
  • Last login:Today at 08:24:26 am
« Reply #5 on: October 22, 2009, 01:05:49 am »
I cheated on my 4 slot resto:
more pix linked in my sig
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« Reply #6 on: October 23, 2009, 09:50:07 am »
First off congrats on the Neo restore.
Mr. Layton is correct EXCEPT there are many different models of the 4 slot cab. I have the smaller 4 slot version. The version you have does need the panels and I happen to have the EL panels you need.  I pulled them off of a cab that had water damage to the cab, but the components (LED credit panels, memory card reader etc. all work fine. As for the EL panels you need I haven't been able to test them but if your interested in buying them I will get them tested.LMK I haven't seen a complete EL panel sell so I'd imagine they are pretty pricey but sinceI have no need for them I would be willing to sell them fairly cheap with the wiring and the power board.
XBL:Mykungfooizgood
PSN: Mykungfooizgud
Oni2382
« Reply #7 on: October 23, 2009, 09:55:16 am »
Also did your 4 slot come with any MVS games????
XBL:Mykungfooizgood
PSN: Mykungfooizgud
SirPeale
  • Green Mountain Man
« Reply #8 on: October 23, 2009, 10:48:03 am »
So you don't want the locks I ordered for you?
