Software Support > DOS/WinCab
Sound stuttering badly at page change over
<< < (6/6)
david656:
Hi,
Great to hear that you are making progress  ;D
Would it be possible to get a copy of wincab with the flac support you have? as i would like to make sure all my albums are named correctly and look ok in my skin  :)
thanks again
David
Chris:
--- Quote from: david656 on October 29, 2009, 07:47:55 am ---Hi,
thanks again
David
Unfortunately, even that rudimentary support is enough to prevent the DOS version from compiling.   This is probably going to be enough to prevent me from supporting FLAC unless I can find a truly cross-platform library for it.
david656:
Hi,
I may be well out here, but SKJukebox has flac support yet uses windows media player as its base. Does it work totally different to wincab?
thanks again for looking into this, it will be a real shame if flac support isn't a viable feature any time soon
Chris:
Yes, quite different... DWJukebox supports both DOS and Windows ("DWJukebox", in fact. is short for "DOSCab and WinCab Jukebox", with DOSCab Jukebox being its original name representing its purpose for DOS-based MAME cabinets) so using Windows Media Player as it's base would not be feasible.  In fact, the only reason DWJukebox exists is because at the time I started work on it seven years ago there was no viable jukebox available for DOS and I needed one.
david656:
Yeh,
I've used your software for quite some time, i tried the DOS version a while ago, and use the windows version on my arcade machine.
I hope that at some point you manage to add flac support as it would be a brilliant asset to a brilliant piece of software.
In the mean time, which format would you recommend? mp3 320kb/s?  What is ogg. i have a few tracks in that format
Again thanks for looking into this.
Navigation
[0] Message Index
[*] Previous page
Go to full version
