Author Topic: Bezel Ideas  (Read 7461 times)
Ginsu Victim
  • Comanche, OK -- USA
Re: Bezel Ideas
« Reply #40 on: October 16, 2009, 09:30:35 pm »
Sorry for "derailing" the thread. :lol
Franco B
Re: Bezel Ideas
« Reply #41 on: October 17, 2009, 03:41:33 am »
Groan!  ::)  :laugh: ( :applaud: ;))
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Bezel Ideas
« Reply #42 on: October 17, 2009, 08:24:01 pm »
and Charlie
SCARED!
Can't sleep.... train will eat me...!  :o >:D
whines
  • Last login:July 06, 2023, 05:02:21 pm
Re: Bezel Ideas
« Reply #43 on: October 18, 2009, 10:09:48 am »
What you want to ask for is 'Foamcore'. It's fine-celled foam sandwiched between two layers of thin cardboard. It's used to build architect's models.
Normally the foam is white and just the cardboard is colored, but there's a version that has black card with black foam--that's what you want.
Use a sharp, new blade to cut it and you shouldn't have any problems.
It's light and rigid and will keep its shape well. if you need to curve it, cutting a series of paralell shallow lines through it should let it curve to the shape you want...I haven't tried this myself though!
Ginsu Victim
Re: Bezel Ideas
« Reply #44 on: October 18, 2009, 11:17:14 am »
We've mentioned foamcore. I use it myself.
If you can cut it and it turns out nice, you're a genius. No matter what I do, that stuff always messes up somewhere during the cutting process.
spOOf
  • Last login:March 27, 2010, 04:36:21 pm
Re: Bezel Ideas
« Reply #45 on: October 28, 2009, 10:53:08 am »
I'll try it out and let you guys know.  Good point about the tapping though.  I'll have to make sure I do that really well so it doesn't bleed through.
Okay, I did some painting over the weekend and put 3 or 4 coats on the plexi using a roller.  I tapped it carefully before hand.  Let it dry and pulled the tape off.  Looked beautiful!  It bled under a little bit at a corner, but it's easy to scrap off with even your fingernail.
I'm so happy I found this thread.
I'll post photos of the "bezel" as soon as I load them up.
My project: The Royal Flush
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
Re: Bezel Ideas
« Reply #46 on: October 28, 2009, 12:43:00 pm »
Best way to cut that stuff is with a HotWire cutter. We used to build them all the time for use in models.
http://www.terragenesis.co.uk/infopages/page171.html check it out here. And you can up the voltage for hotter cutting.
Best of the Best of the Best. Sir!
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 23, 2023, 07:05:04 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
Re: Bezel Ideas
« Reply #47 on: October 28, 2009, 10:14:13 pm »
I have had incredible results with the spraypaint-behind-tinted glass approach. It isn't authentic (at least I've never seen it on a 'real' machine) but it looks better than any cardboard or plastic bezel I have ever seen.
Endaar
  • Last login:November 11, 2015, 07:18:45 am
Re: Bezel Ideas
« Reply #48 on: October 31, 2009, 10:42:11 pm »
This whole bezel issue stinks. I spent more time on my bezel than almost any other part of my project, and I still don't like how it came out.
I agree it's nearly impossible to cut the foamboard cleanly, and even if you do so, you still have something like a 1/4" ugly edge that you're looking at. I ended up buying custom-cut matting (that you'd normally use when framing a picture) which looks a lot better.
Endaar
IG-88
  • Last login:May 09, 2023, 08:29:46 am
Re: Bezel Ideas
« Reply #49 on: November 01, 2009, 08:15:37 am »
Where did you get that matting at? Local frame shop? How much was it?
-HarumaN
