Main > Main Forum
A Closer Look At The AimTrak (with video goodness)
thatitalian:
:dunno
Silas (son of Silas):
--- Quote from: thatitalian on November 09, 2009, 08:58:53 am --- :dunno
+ 1
AndyWarne:
--- Quote from: Ginsu Victim on October 22, 2009, 01:11:21 pm ---Speaking of PC applications, any word on a new version of the AimTrak software?
Just an update: Still working on the new version and also new firmware. There are quite a few changes so its taking a while. Will be ready as soon as possible.
Andy
Ginsu Victim:
Thanks for the update
jlfreund:
Although curvature of the CRT may be responsible for some of the inaccuracy at the left/right of the monitor, it seems like the accuracy is best inside a "V" from the center to the top two corners of the screen. Ie, nearest the top sensor bar.
I'm wondering if it should be possible to duplicate that accuracy in the other quadrants just by using 4 sensor bars? It seems like it should be easy from an algorithmic point of view to just report the location from the nearest sensor bar and ignore the rest of the sensors.
Since the sensor bar hardware is relatively cheap, I would expect the improvement would be worthwhile with respect to a $200 dual gun setup.
