Author Topic: FORCING MAME TO LAUNCH ALL GAMES WITH PIXEL ASPECT VIDEO MODE  (Read 10161 times)
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« on: October 11, 2009, 04:37:07 pm »
I am running MAME 0.128 through the latest version of MALA.  Is there a way to have MAME or MALA force all games to launch in pixel aspect video mode?  As it stands now, my games are launching with all artwork and backgrounds by default, which makes the playing screen too small for my system.
Thanks.
Galaga... Was there any other game?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: FORCING MAME TO LAUNCH ALL GAMES WITH PIXEL ASPECT VIDEO MODE
« Reply #1 on: October 11, 2009, 06:29:52 pm »
"pixel aspect video mode"?  "I do not think it means what you think it means."
How about just disabling the artwork?  Or removing the art files?
You see, there are many issues you can run into trying to go "pixel perfect".  Mame's defaults are generally what's best for most computers.  I could go into details, but... what monitor are you using?  If it's LCD, let mame and directX scale it.
Robin
Knowledge is Power
LeedsFan
  • Last login:January 17, 2021, 06:14:23 am
« Reply #2 on: October 12, 2009, 02:51:25 am »
All you have to do is go into your Mame folder and locate your Mame.ini. In that text file you will find a section for the artwork including things like Backgrounds, Bezels, Overlays etc.
0=off and 1=on. Just change and save as you see fit. I personally find that the bezels are the ones that make the gameplay area change. Space Invaders and Mr.Do have the gameplay area go very small with Bezels on, though they do look very nice.
BamBam
« Reply #3 on: October 16, 2009, 07:41:02 am »
After launching a game I hit "Tab", which brings up the configuration window.  I then select "video" where I have options for "4x3"; Pixel Perfect, "Bezels" etc.  When I select "Pixel Perfect, I like the look of it on my CRT 19" monitor.
SGT
  • Last login:April 17, 2023, 08:29:42 pm
« Reply #4 on: October 16, 2009, 11:45:36 am »
I don't have an option "Pixel Perfect" in the latest Mame.  Did you mean "Pixel Aspect 7:8"?
Find a cfg (in the mame/cfg) folder for a game that you changed to the aspect ratio that you like.   Open this cfg file and see what setting is in there.
It may have a line like:
Code: [Select]
view="Pixel Aspect (7:8)"
That tells you what line in mame.ini file that you need to change in order to make this change for ALL roms.  If you don't have a mame.ini file, you can create one from a command line with:
Code: [Select]
mame -cc
Edit mame.ini with notepad and depending up what you found in that specific roms cfg file make the change.  For example:
Code: [Select]
view          "Pixel Aspect (7:8)"
Save it and restart Mame.   This example may not be applicable depending upon what version of Mame you are running.
« Last Edit: October 16, 2009, 11:51:00 am by SGT »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: October 16, 2009, 02:06:46 pm »
oh, that pixel aspect.
Those numbers vary game to game; it's based on the original resolution, so there are over one hundred of different numbers.  Luckily mame is okay at guessing:
view "Pixel Aspect ("
Should do it for all games.  (At least it worked on the two games I tried with 0.134.)
I hope you have a multires CRT monitor.
Robin
Knowledge is Power
SGT
« Reply #6 on: October 16, 2009, 02:55:01 pm »
I didn't realize that varied from game to game.  Hey what does that "(" mean?   Is that a wildcard character?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: October 16, 2009, 06:30:22 pm »
Nothing special.
Mame tries to figure out "close" misses.  The "(" was the first one in your example, or the last character I used from your exammple, depending how you look at it.  I tried it without it (just "Pixel Aspect") and mame couldn't figure it out.  With it, mame was able to in the two games I tried (smashtv & arkanoid).   :dunno Go figure.
Robin
Knowledge is Power
SGT
« Reply #8 on: October 16, 2009, 06:46:47 pm »
Nothing special.
Yep, I am an idiot.  I forgot that the 7:8 had parentheses around it.  Thanks u_rebelscum.
BamBam
« Reply #9 on: November 01, 2009, 02:40:52 pm »
So does that mean that I need to edit the Mame.ini to reflect the "view "Pixel Aspect ("" mode?
Thanks for the replies on this.
SGT
« Reply #10 on: November 01, 2009, 04:36:44 pm »
Yeah, find the view line and change it to:
Code: [Select]
BamBam
« Reply #11 on: November 03, 2009, 07:10:33 am »
Thanks SGT.  I'll give that a whirl. :applaud:
« Last Edit: November 03, 2009, 07:35:32 pm by BamBam »
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #12 on: November 23, 2012, 02:36:52 pm »
Sorry to revive and old topic:  But for some reason I can't get Gorf to display in 4:3.
Here's my issue:  When in the game I hit tab and select Standard (4:3) and it looks great, but then when I exit the game and go back in, I have to do it all over again.  Changes are not saved.
Any idea what the command would be for the .ini file?
The command view "Pixel Aspect (" works but it defaults to 15:22.  I would like it to be at 4:3.
Thanks in advance!
DeLuSioNaL29
Yenome
  • Last login:April 12, 2024, 01:03:06 am
  • Punch a fish. Make a wish
« Reply #13 on: November 24, 2012, 12:27:12 pm »
go into the cfg folder and find gorf.ini and add this
 <video>
            <target index="0" view="Pixel Aspect (4:3)" />
        </video>
mine is under system and above counters. also check the write permission on the folder. make sure its not all read only
« Reply #14 on: November 25, 2012, 01:05:16 am »
Thanks for the advice.  I tried copying and pasting it and it turns out it didn't work.  I also checked to make sure the directories are not read only.
I ended up updating the gorf.ini file to the following:
"Pixel Aspect ("
effect none
It defaults to the h15:22 aspect, which is fine, but the effect scanlines divides the screen in two.  So I needed to disable the effect in order for it to look good.  I'll take it at this point.   :-\
Thanks for your help everyone.
D
Yenome
« Reply #15 on: November 28, 2012, 12:39:49 pm »
yea not sure how close those files follow the format ruling it might have to be formatted right. but least you found something that works. tho im not satisfied with it for you if that makes sense lol.
