Author Topic: Huge, huge problem.  (Read 6958 times)
Chukka
  • Last login:January 28, 2021, 04:28:30 pm
Huge, huge problem.
« on: October 11, 2009, 02:40:53 pm »
Hi,
I tried changing the Windows XP startup screen according to these instructions:
http://www.nwarwick.co.uk/Windows/ChangeXPBootScreen.html
I also deleted the recycling bin from the desktop by following these instructions:
http://www.overclock.net/faqs/115397-how-remove-recycle-bin-shortcut-your.html
Now, my Windows XP won't boot. Not even in Safe Mode  :'(
What should I do???  ???
Thanks in advance!
Epyx
  • "You're an oddity"
Re: Huge, huge problem.
« Reply #1 on: October 11, 2009, 03:02:26 pm »
Just do a repair installation.  A repair installation will retain your existing files/settings but fix the windows system files.
http://michaelstevenstech.com/XPrepairinstall.htm
Last Project
Epyx Tutorials:
Tutorials
Chukka
« Reply #2 on: October 11, 2009, 03:05:02 pm »
My CD-drive won't open. I don't know why?? Maybe because windows won't load??
Epyx
« Reply #3 on: October 11, 2009, 03:12:55 pm »
Your CD/DVD drive should have a small pin sized hole near the bottom of the tray. Inserting an unfolded paperclip gently into the hole will force the tray mechanism to open. The tray not opening shouldn't have anything to do with Windows working or not...if the drive is receiving power it should eject. Try powering down completely first and trying again...if not use the paperclip method I referred to.
Last Project
Epyx Tutorials:
Tutorials
Chukka
« Reply #4 on: October 11, 2009, 03:29:38 pm »
Is there any way to do the XP repair from an external drive?
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #5 on: October 11, 2009, 04:38:38 pm »
There should be no need to if you have a valid copy of Windows XP.
Galaga... Was there any other game?
Chukka
« Reply #6 on: October 11, 2009, 04:45:36 pm »
"My CD-drive won't open. I don't know why?? Maybe because windows won't load??"
« Reply #7 on: October 11, 2009, 06:32:08 pm »
It could be jammed. Esp if they sit at an angle or vertically.
There's usually a pinhole on the front of the CD drive.
Take a paperclip, straighten it and poke it in the pinhole, that will usually eject the disc (manually, though so once it partly out, you'll have to pull the tray the rest of the way.
Epyx
« Reply #8 on: October 11, 2009, 07:14:48 pm »
I mentioned that a few posts above ;)
Last Project
Epyx Tutorials:
Tutorials
bkenobi
« Reply #9 on: October 11, 2009, 09:06:15 pm »
Try a different CD drive.  If it's really jammed, you should get a new one.
Bender
« Reply #10 on: October 11, 2009, 09:07:14 pm »
I had to do this once or twice :banghead:
it's most likely that the boot screen you replaced isn't the right format. XP is very picky about the resolution, bit depth, # of colors and even the interlacing of the image
I took the hardrive out put it in another enclosure and hooked it up to another machine and copied the boot screen back in
and put the HD back in the original machine and it booted up fine
then I did a bunch of research on the boot screen image info before I did it again
by the way I got that suggestion from this forum saved ---my bottom---!
Good Luck!
Finchbyrd
  • Last login:November 08, 2009, 06:03:22 pm
« Reply #11 on: October 11, 2009, 09:40:14 pm »
Use a program to change the boot screen, don't rename it or edit any kernals or anything. You'll brick, as you've witnessed.
Ummon
  • Trade Count: (+13)
« Reply #12 on: October 11, 2009, 10:03:44 pm »
Good Luck!
Segue:
I can only guess that this is showing as censored because you have your settings that way - I don't - and if yer gonna cuss, you might as well let us see it. Eh?
Yo. Chocolate.
Stephen Hawking
« Reply #13 on: October 11, 2009, 10:53:16 pm »
@epyx
Doh! Guess I should read more  :-[
What's a CD drive these days, 5$? If the pinhole trick doesn't work, I'd agree with kenobi. Pitch it.
Although, i've heard there's cool stuff you can do with the laser in those things.
Never tried anything myself... Yet....
Finchbyrd
« Reply #14 on: October 11, 2009, 11:37:31 pm »
I've never heard of a drive not opening because of an OS, unless you went in there and started yanking cables it could be serious. Do the paperclip trick or yank it.
Bender
« Reply #15 on: October 12, 2009, 02:57:27 am »
Good Luck!
Segue:
how's this?
Saved my shinny metal ass!
mytymaus007
« Reply #16 on: October 12, 2009, 08:33:09 am »
Buy a new PC :laugh2:
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #17 on: October 12, 2009, 01:27:16 pm »
First and foremost...  Try updating the title of this topic.  Can you be any more generic?
Perhaps you will get a greater response when you are specific in what you need help with.
Just a thought.
D
shatteredzman
  • Last login:January 06, 2013, 11:44:35 pm
« Reply #18 on: October 12, 2009, 01:40:54 pm »
A cd drive will open even with a faulty operating system, how else would you install the operating system on the computer for the first time? Your drive is most likely jammed, do what the others suggested and poke a paper clip in that hole, it will free the drive. If that doesnt work take the drive out of the computer and turn it over, shake it, tap it, or do whatever to try to loosen the jam. The drive doesnt even need to be connected to the data cable to open, just the power.
Chukka
« Reply #19 on: October 12, 2009, 01:44:51 pm »
Just a thought.
D
Eat ####.
Thanks everyone else for their help. The CD drive wasn't working because the power wire wasn't connected properly. I got it working and used the XP CD to rebuild the boot.ini. The boot.bmp was the problem. Got it working now.
Thanks to all the helpful people except Delusional and BamBam.
severdhed
  • RIP Dinosaur Hippo
« Reply #20 on: October 12, 2009, 02:20:00 pm »
Just a thought.
D
Eat ####.
wow, that was rude  ::)
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #21 on: October 12, 2009, 02:24:41 pm »
Chukka,
Don't be an ass.  Hell, learn to read too.   :tool:
eaconner
  • Last login:February 27, 2013, 11:15:42 am
    • WV Arcade Club
« Reply #22 on: October 12, 2009, 02:45:13 pm »
+1 Hoopz
+1 severdhed
« Reply #23 on: October 12, 2009, 06:31:46 pm »
Wow, didn't think I would offend you.  Sorry Chukka.   :dizzy:
As people can attest on this board, I'm all about helping people.  My numerous posts and videos prove it.  I was only trying to help you, since you appeared to be a newbie with under 20 posts.
P.S. - I was nice by not mentioning that it is also in the wrong section.  It belongs in the software forum.
But now you know and everyone is happy!   :applaud:
Happy posting!
DeLuSioNaL
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
Possible causes....
« Reply #24 on: October 13, 2009, 12:11:04 am »
Missed reading the post where you got it working.  I was just about to recommend checking the power supply.  If it isn't putting out the right voltage it can cause these issues.   Won't let me delete this post....
« Last Edit: October 13, 2009, 12:16:46 am by JODY »
Bender
« Reply #25 on: October 13, 2009, 01:32:12 am »
Just a thought.
D
Eat ####.
I don't know if you were joking or not (I hope you were)
But dissing the long time members of the community, who are just trying to help is not a way to continue to get help in the future
Glad you got it working though
jasonbar
  • Last login:July 30, 2023, 02:52:55 am
  • Dr. Inferno
    • The Infernolab
« Reply #26 on: October 13, 2009, 03:08:36 am »
Coming to this party late, but my $0.02:
Using the system mentioned in the referenced page (http://www.nwarwick.co.uk/Windows/ChangeXPBootScreen.html) worked just ducky for me.
Trying Bootskin 1.05a was awful.  Got BSOD immediately upon boot on my laptop, my work PC, & my MAME cab (all running XP).  Couldn't get it to work.  vidstub.sys in c:\windows\system32\drivers was the culprit.  A boot in safe mode & an uninstall of Bootskin did the trick.  Many of the fixes on-line recommend using 1.02 instead.  Nope, still get BSOD immediately upon boot (but with a different error, something about IRQ not being less than or equal to something...).
Thanks,
-Jason
PS--on Windows XP Pro, I was able to right click on the desktop & follow through a few buttons & such till I found an option to hide all desktop icons.  Strangely, I can't find it on my Win XP Home on my laptop... :dizzy:
« Last Edit: October 13, 2009, 03:17:29 am by jasonbar »
Chukka
« Reply #27 on: October 13, 2009, 03:46:31 am »
Happy posting!
DeLuSioNaL
Sorry DeLuSioNaL. I've been reading your stuff for a long time and I know you're a good guy. I wasn't being serious  :) (well, a bit  ;) )
Chukka
« Reply #28 on: October 13, 2009, 03:52:45 am »
Thanks,
-Jason
http://forum.arcadecontrols.com/index.php?topic=53467.0
I actually used this first post for help and got it working almost the way I like it. The Taskbar still pops up for a second before the FE loads. And I still need to do something about the mouse cursor. Other than that, it's getting there. Now I just need a kick ass intro video like DeLuSioNaL's. Mine is horrible  :laugh2:
Kman-Sweden
  • Up the Irons!
« Reply #29 on: October 13, 2009, 04:22:48 am »
About the mouse cursor.... I've posted this before but here it comes again...
Hiding windows: Damn those standard cursors!
Ok here's how you hide the cursor completely at startup of Windows XP... Remember who gave you this solution.
If you'd like to change the cursor in your control panel to let's say, a dinosaur or a tiny arrow. You'll still have the standard white arrow cursor displayed for about one second when you startup and shutdown Windows. This is because the standard cursor is shown before (and after) the user defined cursors are loaded. So to hide the cursor we need to replace the standard cursors....
The standard cursors are stored in the User32.dll file.
And to make things worse the user32.dll is backed up in dllcache.
We'll backup then edit the user32.dll and replace it in it's original place and in the dllcache.
You'll need the following..
1.) A blank cursor, or the smallest one you can live with showing at bootup and shutdown.
2.) A Windows XP install CD.
3.) ResHack program get it here ----> http://www.angusj.com/resourcehacker/
4.) Administrator password to the PC (if any).
In this example I'll call the cursor for blank.cur.
Put you blank.cur in the cursors folder in your windows directory. (c:/windows/cursors)
Just so you know where you have it.
Download and extract Reshack to any folder. Run the "ResHacker.exe" from that folder.
Click on "File" and then "Open". Browse to the user32.dll file (c:\windows\system32\user32.dll) and open it.
Expand the cursor folder, here you'll find all standard cursors neatly setup in their own folders. Find the cursors you'd like to change. I chose to replace the "arrow" and the "arrow and hourglas". Rightclick on the flower-icon for the cursor you'd like to replace and choose "replace resource". Replace it with the blank.cur that we placed in c:\windows\cursors.
Repeat with any other cursors you'd like to replace.
The next IMPORTANT step is to select "SAVE AS"!!! not "save"!!
Save it as user32new.dll in the c:\windows\system32 folder.
Next step is to replace the user32.dll file(s).
Insert the WinXP CD-ROM into the CD-ROM or DVD-ROM drive and then restart the computer. Select any options that are required to start the computer from the CD-ROM or DVD-ROM drive if you are prompted to do so.
When the “Welcome to Setup” screen appears, press R to start Recovery Console.
Here you might be asked to enter the admin password.
At the command prompt, type the following command, and then press ENTER:
cd windows\system32
To rename the User32.dll file, type the following command, and then press ENTER:
ren user32.dll user32.bak
Then rename the User32new.ddl to user32.dll by typing the following command, and the press ENTER:
ren user32new.dll user32.dll
The final step is to replace the backup windows stores in the dllcache folder.
copy your user32.dll to the dllcache folder by typing the following command,
copy user32.dll c:\windows\system32\dllcache\
Press "Y" to overwrite the file and your done.
Take out the Windows XP cd and type exit in the prompt to exit the Recovery Consloe and restart your PC.
Now the arrow cursor at startup will be replaced with your blank.cur.
Note that when Windows has started the cursor that's set in cursors in your control panel WILL be shown.
ENJOY!
smalltownguy
  • Last login:February 13, 2023, 10:48:26 am
« Reply #30 on: October 13, 2009, 06:49:09 am »
The big ticket here is to make sure you are not booted to the disk in which you want to change the user32.dll file on. Windows won't let you do it, since the file will be in use. More so, it will re-create the file upon exit. Kman's method is the 'standard,' although I do know of a few alternatives.
One alternative to doing this if you don't have easy access to an XP disc is to boot the computer to DOS using any other boot disk that will load your file system. I have the BartPE disc, so I used that.
Or, you could piggyback the drive on to another computer as a slave, and then you'll have the privileges you need to replace that .dll file, since it won't be in use as a system file.
This was the last thing I needed to do to completely hide all traces of windows on my setup. It is now impossible to tell that there's a PC in my cab. No blips, no nothing. I'm very pleased ;D
whatever method you like  :cheers:
p.s. Shameless plug of my cab! An old video of my cab's start up/shut down. I used Bootskins. I have since upgraded the memory (fixes the blip at the start of MAME) and modified my MameWah layout to remove the gray square that flashes at startup. I'm working on a video now of my AimTrak, and I'll try to capture the startup routine in that. Will post then.
Kman-Sweden
  • Up the Irons!
« Reply #31 on: October 13, 2009, 07:58:50 am »
Cool how did you hide DOS pre-boot?
smalltownguy
« Reply #32 on: October 13, 2009, 08:00:17 am »
I'm using a CRT monitor, so it just takes that long to warm up.
« Reply #33 on: October 13, 2009, 12:25:40 pm »
You can view a great guide here:  (This is what I use):
http://forums.maximusarcade.com/viewtopic.php?f=1&t=506
Here's an excerpt from that guide.  I only used this part, as I don't really want MA to boot as my main shell.  :)
"PART 3: Things you might as well do if you made it this far (all optional, but cool)
a) Hide the "Loading Settings" popup
-run regedit and go to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
-Create a DWORD value called "DisableStatusMessages", and edit its value to the number 1
(or edit this dword if it already exists, which it likely doesn't)
b) Kill the Welcome and Startup/Shutdown screens
-in regedit go to:
HKEY_USERS\DEFAULT\Control Panel\Colors\Background
-change the value to: 0 0 0 (those are zeros, and the spaces ARE necessary)
-now, go to the Control Panel -> User Accounts and select "Change the way users log on or off". Uncheck "Use Welcome Screen"
c) Kill the pop-up bubbles like "USB device connected" "Not all Star Menu Objects can be shown", etc
-run regedit yet again and go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
-Create a DWORD named "EnableBalloonTips", and give it a hex value of "0" (zero)
d) Get rid of the WinXP bootscreen
-This is how i did it. There are programs that can give you the full featured ones with progress bars, etc, but my new bootscreen is the "Winners don't use drugs" screen from old arcade games, so it's a static image. It's perfect. :) Plus it's the easiest/least accident prone method of changing it.
-Make a 640x480 16-COLOR bitmap. It MUST be saved or converted to a 16-color bitmap. Or ask me for mine. Name it "boot.bmp" and keep it in your c:\windows directory
-Go to My Computer -> Properties -> Advance -> Startup and Recovery -> Settings
-Click "Edit Startup Options" and add the following to the end of what's there:
/bootlogo /noguiboot
(make sure you leave a space between the existing options and the ones you added above, and keep a space between the two new options while you're at it)"
P.S. - I'm almost done editing my intro for me to share with all to use.   :applaud:
DeLuSioNaL
Kman-Sweden
  • Up the Irons!
« Reply #34 on: October 13, 2009, 12:54:16 pm »
You get around this problem using my guide since I "save as" the file and then rename the file, to the correct name when you're in the "Recovery Console".  :afro:
DeLuSioNal29 ---> Nice work in shortening one of the longest posts in the Maximus Forum.  :cheers:
Chukka
« Reply #35 on: October 13, 2009, 05:42:39 pm »
-in regedit go to:
DeLuSioNaL
Everything else is fine except the taskbar now. It pops up twice (First loading LedWiz and then loading the FE) even though I have it switched to auto-hide and always minimize it before turning off the machine. Any ideas?
smalltownguy
« Reply #36 on: October 13, 2009, 05:48:41 pm »
If you're seeing the taskbar, then you must not be shelling MA. Was it your intent to run it as a shell, or are you just trying to keep explorer but hide it as best as possible?
I'm not aware of any way to completely remove all instances of windows showing itself if you load explorer as your shell, only if you shell your frontend.
Could be wrong.....  :blah:
Kman-Sweden
  • Up the Irons!
« Reply #37 on: October 14, 2009, 02:46:35 am »
Smalltownguy is right. you need to hack the registry so your FE .exe is loaded instead of explorer.exe.
Have a look at the "Hide Windows" post in Maximus arcades fourm.
Chukka
« Reply #38 on: October 14, 2009, 03:39:23 am »
No I wasn't planning on shelling MA. Will LedWiz etc. load properly if you don't start explorer?
Kman-Sweden
  • Up the Irons!
« Reply #39 on: October 14, 2009, 04:31:13 am »
yes.
