Main > Main Forum
CP Assembly Questions
Pages: << < (2/2)
Honkyharris:
--- Quote from: Kman-Sweden on October 07, 2009, 10:04:02 am ---I'll top mount everything. I'll do the top of the CP in a thinner MDF so that MDF + Plexi = 3/4".
Thisway the t-mold helps holding the Plexi in place.
This is another option, but a much more expensive one. I already have a panel cut out of 3/4" which I wanted to do to make the top beefy. It would be nice to have the t-molding help, but my layout has a total of 18 buttons located throughout the cp which I would think would be enough to hold it in place. My only real concern is the edges.
If I were to make another cp not only would this take more time, but would also require that I bought another thinner MDF board at a cost of $25 or so.
Honkyharris
Honkyharris:
--- Quote from: Ginsu Victim on October 07, 2009, 10:09:09 am ---I'm not sure how much to route (I never do), but you might want to use the mounting kit from Ultimarc.
http://www.ultimarc.com/controls.html#mountingkits
I have the mounting kit for the trackball, I just wasn't sure about the joysticks. I'm concerned about the height of the joystick (above the top of the cp) when it is bottom mounted. I guess this is why I'll be doing some test installs :)
Honkyharris
Ginsu Victim:
I've bottom mounted U360s with the regular shafts and Happ Competitions (again, no routing) and the length was fine by me, but might not be okay for everyone.
Honkyharris:
--- Quote from: Ginsu Victim on October 07, 2009, 10:15:47 am ---I've bottom mounted U360s with the regular shafts and Happ Competitions (again, no routing) and the length was fine by me, but might not be okay for everyone.
Well i'll certainly look into it. Thanks again for the help.
Honkyharris
Nacimroc:
--- Quote from: Honkyharris on October 07, 2009, 09:22:34 am ---   Lastly, my cp will be 3/4" MDF and my t-molding I've ordered is fit for 3/4" . The plexi or protective layer is going to sit above the molding which I thought might look bad. Is this standard practice? I was thinking of putting a rounded bevel on the edge of the plexi and then allowing it to sit 1/8" above or so (depending on the thickness of the protective layer) would not be a big deal. Please advise.
Just starting my first build so no expert, but I bought 13/16" T-Molding instead, allowing for room for plexi to be covered!
Pages: << < (2/2)
Go to full version
