Main > Project Announcements
Raiden Cab Project - New Pics with coin door. 98% finished (for now)
Pages: << < (10/11) > >>
rablack97:
Not sure about the pot, but the little box at the bottom could be the play counter.  Arcades used them to track the # of times the game was played.  I just disconnected mine and took it totally off.  I yanked all the excess wiring which left me with basically 12v & ground for the lights and ground & trigger for the coin mechs.
I just use a third party program to control the volume using key combinations....
Send a PM to OND, he's a electronics guru, he's pretty good about responding too....
BurgerKingDiamond:
Thanks. I decided that whatever it is it doesn't matter cause I was able to hook up my lights and coin switches without using it.
Silas (son of Silas):
--- Quote from: Epyx on March 23, 2010, 11:22:16 am ---I would disagree only in that laminating is *much* quicker than a great paint job.  A side of a cab can be laminated and routed within 45 minutes:
-5 minutes to trace outline of side on laminate
-10 minutes to slop on glue
- 20 minutes to dry
- 5 minutes to press laminate on side
- 10 minutes to route it
If you use spray on contact adhesive it's even quicker. 2 minutes to spray on the glue, 5 minutes to dry; plus there's less likelihood of any glue bumps.
BurgerKingDiamond:
some new pics
BurgerKingDiamond:
some new pics
Go to full version
