Main > Project Announcements
Raiden Cab Project - New Pics with coin door. 98% finished (for now)
Pages: << < (7/11) > >>
SpaceHedgehog:
No problem! From what I've read, they are M5 size button head hex socket screws. You should be able to source these fairly easily. There's a link to some examples here:
http://www.instockfasteners.com/PRODUCTS/hexsocketscrews.asp
If you fancy something with a little more bling:
http://forums.gameaxis.com/showthread.php?t=1513682
BurgerKingDiamond:
I got rid of my old 17" Rotating LCD and replace it with a 27" Sony CRT TV for $70 connected through S-Video. It fit's perfectly ( I guess I got lucky). The picture quality is awesome (except for reading text in windows, but I just use the laptop for stuff outside of MALA). To anyone who's using an LCD monitor I would really recommend just putting in the biggest CRT TV that will fit in your cab and connect it through S-Video. It makes a huge difference.
Coming up I plan on making the bezel, replacing the black T-Molding with blue, laminating the exterior and adding a coin door. I'll post pics/updates as they come.
BurgerKingDiamond:
Can someone explain to me how to insert picture in the middle of text instead of having all show up at the bottom of the post?
Kurt:
You need to host them at www.photobucket.com or something along the lines.
It's free then you link an image to the img hosted address from photobucket etc etc.
Hewskie:
or you can just post them in the sticky at the top of project announcements. make a blank post of your pictures, then open the post and copy paste the link locations to your project thread post with an img tag
Go to full version
