Author Topic: Removing Joysticks from an SNK P.O.W. Please help!!!  (Read 1437 times)
RUP
  • Last login:August 13, 2013, 09:21:12 am
« on: September 27, 2009, 12:48:36 pm »
Does anyone know how to remove the Joysticks from an SNK P.O.W. control panel?  I took off the nuts but there seems to be another star shaped nut behind it.  Do I need a special nut driver to remove this? Please help! Thanks, Rup
ammitz
  • Last login:April 25, 2017, 07:22:09 am
Re: Removing Joysticks from an SNK P.O.W. Please help!!!
« Reply #1 on: October 01, 2009, 04:51:46 am »
Would it be possible to take a picture?
Building my first bartop CAB
RUP
« Reply #2 on: October 01, 2009, 06:40:51 pm »
The star shaped nut turned out to be a washer.  I got that off but there is still something holding it on.  Here's a picture.  Thanks for ther help!
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: October 01, 2009, 07:29:18 pm »
I see nothing. Are you sure the base isn't just tight around the bolt?
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #4 on: October 02, 2009, 09:49:56 am »
It should just come right out because that is all that is holding my joysticks in place are those 4 bolts and nuts unless the  :tool: that worked on the machine before put some sort of glue.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
RUP
« Reply #5 on: October 05, 2009, 08:55:43 pm »
Hey Guys, Thanks for the help!  After I got the washers out of the bolt holes I used the tool below to get under the control panel and the joystick to pry it off the bolts! Thanks again!
mwong168
« Reply #6 on: October 06, 2009, 10:40:17 am »
So I guess there was some sort of glue if you had to pry it off?
RUP
« Reply #7 on: October 06, 2009, 08:51:14 pm »
Yes there was some sort of glue in and around the bolt holes!!! Never underestimate the power of stupid people I guess!  Why would you think you need glue there?!?!
