Main > Main Forum
My hole is rough as a badgers arse!
<< < (2/2)
AlanS17:
He never mentioned anything of a bionic badger, though... I would imagine that would be shiny smooth.
Spaced Invader:
I'm not exactly a rough hole expert...though I have encountered more than one.  ;D
Hmm...
Maybe you could make a bezel of some sort--mini Cd covered with Vinyl maybe? Just adding my thoughts to the list...I'd try the dremel or rubber seal first...but what do I Know?
And there's always Duct Tape!
Xiaou2:
 Actually, Dremels Stink.  I hardly ever use mine... as its dangerous... and the tools (cutting/sanding/ect) fade away too fa$t to do any large heavy duty work such as needed here. (also slow to do large work)
 You can pick up some Much heavier duty grinding bit ends for your drill.   Use these to gring the surface flat - then touch up with sandpaper in varying grits till smooth.
 Ive use these drill grinder bits with my drill press for excellent results.
gndprx:
Not normally one to state the obvious here, but a simple file would clean that up in a few passes.
Just a suggestion  ;)
Lilwolf:
But the question is how accurate is your statement?
I mean... did you have the Badger next to your control panel when compairing?  And was it just a visual compareson or did you make multiple tests?
Now that you've cut it, there isn't much to do but file.
but for next time.  Start the whole from the side you want to be clean.  Start very very slow.  Make sure you have a sharp drill bit.   Not much you can do about it other then that.
Navigation
Message Index
Previous page
Go to full version
