Main > Project Announcements
BLACK'S MAGIC- 100% Structurally COMPLETE - PHOTO UPDATES 7-23-2010
rablack97:
Ok I need help deciding which CP art to use......
I just removed the wizard and replaced with a nice Raiden Graphic.....
Sucks that I already have the wizard CP printed.....Oh well, not the first redo in this whole project...
Original
Updated
Gamester:
Personally, I like the wizard one better...
Nice progress!
Epyx:
--- Quote ---Personally, I like the wizard one better...
+1 ;)
kop:
Focal splits in an arcade cabinet. :o I'm very impressed. Should sound awesome when done. Very cool project you have going here.
FWIW I think the wizard looks better.
rablack97:
I wanted to get some input on j-sticks.
Should I go with JLW or JLF.
The difference is in the microswitches, JLW is older uses authentic lever switches and look to have a bigger mounting plate, JLF uses a PCB board and is the new model and seems to be used more for standalone CP's.
Any pros and cons on either.
I was looking at the U360's but I want the lighted ball tops and after research seems thats not gonna happen due to the modifications it needs to make that happen. Plus I cant see myself tearing up and expensive stick like that only to screw up the functionality so i can see pretty lights.
So i'm torn between JLF/JLW, any comments would be appreciated.
