Author Topic: Quick answer to LCD widescreen question?  (Read 811 times)
southpaw13
  • Last login:October 31, 2020, 05:11:18 pm
  • Whatever!
« on: September 10, 2009, 05:44:27 pm »
What size LCD widecreen do I need to emulate a 19" 4:3 display?  Is the height about 12" on a standard CRT?  If so would a 20" widescreen be big enough to emulate a 19" monitor?  I just hate the way they figure the new measurements now...
Thanks for your help everyone...
MaximRecoil
Re: Quick answer to LCD widescreen question?
« Reply #1 on: September 10, 2009, 06:42:10 pm »
23.25" diagonal, viewable.
southpaw13
  • Whatever!
« Reply #2 on: September 10, 2009, 07:40:49 pm »
Thanks...much appreciated!!!!!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: September 11, 2009, 11:47:13 am »
If you're talking 16:9 (TV widescreen), yes it's 23.25".
If you're talking 16:10 (most common computer "widescreen"), it's 21.5".
Then there are less common ratios for "widescreen" computer monitors, like 3:2 which would result in a 20.55" size to match the same height as a 19" 4:3 monitor.
Robin
Knowledge is Power
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: September 11, 2009, 12:46:40 pm »
New measurements, now?  The viewable diagonal has been the standard for decades (for TVs and LCD monitors).  The problem is all the different ratios monitors now come in, making a 22" TV widescren the same size (in area) as a 21.45" 16:10 computer widescreen:
"size"
viewable diagonal
screen ratioviewable area
sq inches
22"
16:9
206.81
21.45
16:10
206.79
20.75
4:3
206.67
20.6
5:4
207.00
When you're comparing screens with the same ratio, diagonal is fine.  When comparing across different ratios, though, diagonals is not the best way, IMO.  I'm not saying area is the best way to state the size.  I sort of like digital camera's pixal count way, as they too come in multiple ratios: 4:3, 3:2 and 16:9.  But people would then realize they are losing pixels when "upgrading" from a 19" 1280x1024 (5:4) to a 1440x900 (16:10) monitor.  Manufacturers don't like that.  ;)
Not that area and pixel count are the way screens should be sized.  But area & pixel count are things consumers should be aware of.  With diagonal and ratio, area can be calculated, and with the usually stated resolution the pixel count can be calculated, so....  As long as people are aware of the ratios and know how to calculate the area & pixel count, diagonals are probably as good (and bad) as any other way to state "size".
Robin
Knowledge is Power
Blanka
« Reply #5 on: September 11, 2009, 02:31:30 pm »
Lets post it again. A scheme to compare all available LCD's to different CRT sizes.
So a 19 inch CRT horizontal compares to 22 inch 16:10 screens or 23 inch 16:9 screens, and vertical its between a 28 and 30 inch 16:10 screen or a 32 inch 16:9 screen.
« Last Edit: September 11, 2009, 02:34:21 pm by Blanka »
