Main > Everything Else
Had network problems - now solved
protokatie:
You may need to set up VPN to access the other computers on that, as each router (in the way you set them up) would have a different set of IP addys.
As per what I said earlier, I did not ask you to hook your wifi device into the router, keep it hooked to your pc, but set up your pc as a server with the router set up as an access point.
There are many solutions, but, your best bet would be to just get your own internet connection (dont see why you dont) and use a single router. This is the least problematic solution. (Seriously, stop being a bumm. Im not kidding.)
crashwg:
Well, I don't exactly see why you're getting on my case about sharing the internet connection... I'm doing it with their knowledge, I can't afford my own high-speed connection and there has never been a bandwidth problem between the two of us.
I will check out what VPN is all about though.
Samstag:
Sounds like you're trying to run two networks in the same subnet. Do both networks start with 192.168.1.x? You'll need to change one of them to another subnet, like 192.168.2.x. You can't have two adapters on the same machine use the same subnet, but as long as they're different you should have no problem using both networks at the same time.
crashwg:
Another problem solved with DD-WRT. Yea so I got a router that supports DD-WRT, loaded that up then set it up as a bridge. Now the four ports on it are an extension of the neighbor's router and we've got one big happy network!
If anybody doesn't know about DD-WRT they should definitely google that shiznit. It's basically an operating system for your router on steroids. It only supports specific hardware though.
Edgedamage:
--- Quote from: crashwg on September 06, 2009, 10:23:03 pm ---Well, I don't exactly see why you're getting on my case about sharing the internet connection... I'm doing it with their knowledge, I can't afford my own high-speed connection and there has never been a bandwidth problem between the two of us.
Sorry man you have all these toys and still can't afford internet??? Your neighbor sounds like my dad he bought a router and left it wide open and had 5 leeches connected to it. Unless you post a youtube vid of your neighbor saying it's ok for you to freeload, I am calling you a leech.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
