Author Topic: Where to find this microswitch?  (Read 1077 times)
acevedor2
  • Last login:January 22, 2022, 07:44:45 pm
« on: September 05, 2009, 10:29:08 pm »
Hey guys - This microswitch is our of the gun on my zombie raid.  I know it's toast, I just don't know where to find one like it.  Any ideas?  Thanks!
Cheers
« Last Edit: September 05, 2009, 10:31:20 pm by acevedor2 »
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
Dr Zero
  • Sunny Florida North
    • Drzero.org
Re: Where to find this microswitch?
« Reply #1 on: September 05, 2009, 11:08:41 pm »
acevedor2
« Reply #2 on: September 07, 2009, 01:34:44 am »
Thanks.  I just hope they don't have a minimum order...  Since I only need 2 :)
Thanks again!
Cheers.
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
« Reply #3 on: September 07, 2009, 02:54:36 am »
Why wouldn't any old microswith work?
Dr Zero
    • Drzero.org
« Reply #4 on: September 07, 2009, 10:33:25 am »
It probably would you just have to get the right shape and have the right little arm on there.
bkenobi
« Reply #5 on: September 07, 2009, 02:09:15 pm »
There's a little more to it than the dimensions, but if you just want it to work (ignoring the feel), then it's not too hard to find a replacement.  If you have the part number off the original, you might be able to find a spec sheet online somewhere.  Different switches have different actuation forces as well as a different MTBF.
I have some LS-30's that one switch failed on.  I couldn't find the exact same switch, but I spoke to Mouser or DigiKey (can't remember which) and they worked with me to find a replacement of the same specs.
Oh, one more thing.  If you can't find a lever arm that's exactly the right length, you can always get one that's a bit longer and cut it to the right dimensions.
Good luck!
