Author Topic: Reducing cabinet plans  (Read 1134 times)
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« on: September 05, 2009, 12:43:37 pm »
Does someone here have the capabilities of taking Jacobuds plans and reducing all the measurements by a third (or whatever) or can maybe explain a quick and easy way of doing it?
-HarumaN
Beretta
Re: Reducing cabinet plans
« Reply #1 on: September 05, 2009, 02:55:40 pm »
ok im not all that great with wood, but it seems to me that simply taking the messurements and cutting off 1/3rd when doing the cutting will yield the result your looking for
example if it says the door needs to be 6x3, then make it 4x2..
simple enough or am i barking up the wrong tree here?
IG-88
« Reply #2 on: September 05, 2009, 03:19:24 pm »
Well, I thought of that too. I was just thinking that maybe there was an easier way (like with sketchup or visio) but you're probably right. Just take the measurement, divide by 3, and subtract that number off the total length.
-HarumaN
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #3 on: September 05, 2009, 09:55:08 pm »
Just multiply every measurement by 2/3.  It's really easy.  I did this to make a mini Ms. Pac-man shaped cabinet (Mine was 80% - 2/3 is really small).  I used Jaokbud's plans too with no major problems.
IG-88
« Reply #4 on: September 06, 2009, 10:39:49 am »
I kinda figured that out but went about it the long way. Not a math wiz thats for sure. I found a neat little calc program that converts decimal measurements into board feet/inches. Once I got that, converting his measurements was a snap.
My idea was to take the top half of one his cab plans, reduce it down by 1/3, and make a bartop out of it. Like the Moon Patrol or something. If I did it right, it should look about right. It measures pretty much the same as my other bartops. And should be easy to have the artwork made for it. Just reduce it down by 1/3 too.... we'll see.
-HarumaN
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #5 on: September 07, 2009, 08:43:19 am »
Hi IG-88,
I would see what reducing the cabinet by a third would give you with regards to the space required for a monitor.
The cabinet size is usually tied into what the size of the monitor is.
A number of the old video cabinets had the board used to fix the monitor to. This board was square so the monitor could be turned dependant on the game used.
Just a thought!
Regards
Alan Hood
ami-man
UK
Franco B
« Reply #6 on: September 07, 2009, 08:46:48 am »
If you struggle with anything else I can always draw it in CAD for you and scale it 0.66
  • Last login:Yesterday at 12:07:27 am
« Reply #7 on: September 07, 2009, 11:23:23 pm »
If you scale it to 0.666 you can open a demonic portal with it  >:D
IG-88
« Reply #8 on: September 09, 2009, 11:41:59 am »
Thanks Franco, I appreciate that. I will keep you in mind.
@ ami-man: I need to build me some cardboard mock ups to see how it looks. I'm hoping that old pc monitors will work, tho not as authentic, the price is right  ;)
-HarumaN
