Author Topic: Auto-powerup cabinet with LCD monitor  (Read 1792 times)
BrianP
  • Last login:April 25, 2020, 10:03:58 pm
« on: September 02, 2009, 03:32:09 pm »
So, I am getting close to finishing my first cabinet (see my thread in the project announcement).  I have been using the book as much as I can.  So, I hit an interesting snag this week and I got ready to buy the PC and the peripherals.
The book talks about getting a 'smart' power strip where there is one master outlet and the other outlets turn off when the master turns off.  So, you hook the PC to the master, when that turns off, everything else turns off.
So, I was thinking about monitors.  The older CRT monitors generally have a physical switch that remains depressed when powered on.  This would work great with the smart strip.  But I was planning a wide screen LCD (rotated 90 degrees) behind plexi.  But I have yet to see a LCD monitor with a physical switch.  And I have never seen one that you can set to auto turn on with power (like most BIOS in computers now a days).
I could (I guess) use the LCD on the master and the PC on the secondary but that could cause issues making sure the PC is shut down before powering off.  I could put a small hole in the plexi and use a paperclip (ewww).  This has me pretty confused right now. :dizzy:
Anyone else tried this?
- brian
BobA
  • What Me Worry?
Re: Auto-powerup cabinet with LCD monitor
« Reply #1 on: September 02, 2009, 03:51:27 pm »
Just leave the LCD screen powered on all the time.   It will default to low power mode when the video signal is lost and will use almost no power in that state.  It will come back on when the signal is received from your computer.
« Reply #2 on: September 02, 2009, 04:32:35 pm »
Well, not sure what LCD you've got, but I've got a dell 2405fpw, and it works exactly like you'd expect.
If you power it up, then UNPLUG the power cable (or in my case, hook the power cable for it up to a smart strip), the smart strip will completely shut it off when I power down the pc.
And when I turn on the PC, the smartstrip restores power to the LCD, which immediately powers on, no button pushing required.
But other lcd's might not work that way.
romshark
  • Last login:October 16, 2023, 02:50:59 pm
  • Arcade and Robotics enthusiast
« Reply #3 on: September 02, 2009, 04:51:09 pm »
We have a number of LCD monitors in our house. All the computer monitors stay on if the external power is cut. I'm not sure about LCD televisions, though.
Just checked one of our televisions (Sharp). It doesn't have an option for coming on. So I'd stay with a computer monitor.
getnate
  • Last login:September 24, 2009, 01:45:27 pm
« Reply #4 on: September 02, 2009, 06:05:46 pm »
Like drventure says... It might work anyways, just plug the LCD in and see if it automatically turns on when the powerstrip is turned on. Mine does, I have a Samsung 214T.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #5 on: September 03, 2009, 05:25:07 am »
The LG I have comes back on when repowered as well. I really don't think you're going to have an issue.
Blanka
« Reply #6 on: September 03, 2009, 06:24:31 am »
A small thing to consider is whether the front of the bezel is flat and no buttons are sticking out. Other than that, you won't have any issues I guess.
And please no plexi, but go for tempered glass  8)
severdhed
  • RIP Dinosaur Hippo
« Reply #7 on: September 03, 2009, 10:22:56 am »
i have had two LCD monitors in my cabinets on a smart strip (one died, i replaced it with a different brand) and they both worked just fine like that.
Haterot
  • Last login:November 09, 2012, 09:27:41 am
« Reply #8 on: September 03, 2009, 12:53:47 pm »
I have a 21" Ausu LCD running in my cab with a Smartstrip I hacked. Runs perfectly fine. You should be good to go.
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
Blanka
« Reply #9 on: November 18, 2009, 04:02:43 pm »
I did not see you wanted to rotate 90 degrees. Make sure you buy an IPS screen then. It's faster than PVA, and it does not have the horrible viewing angles of TN screens rotated 90 degrees.
Don't understand the widescreen too. The HP 2065 is one of the best screens for vertical games. It has an 20 inch 1600x1200 IPS panel, is pretty fast and the viewing angles are excellent. If you still insist on widescreen, consider the Dell U2410 or the LG W2600HP
BrianP
« Reply #10 on: November 19, 2009, 07:43:44 am »
There are some terms I am going to have to google :)
I actually don't really care about widescreen, I just haven't seen a non-widescreen monitor in quote a while. :)
- Brian
