Author Topic: I need new plexi  (Read 622 times)
dieseldogpi
  • Last login:October 27, 2011, 02:40:41 pm
I need new plexi
« on: September 01, 2009, 09:38:25 pm »
Where do I look to get new plexi glass for my control panel on my Golden Tee Fore?  I really would rather have something done professionally, anytime I've messed with plexi, it comes out pretty rough.  Thanks.
Epyx
  • "You're an oddity"
Re: I need new plexi
« Reply #1 on: September 01, 2009, 10:33:24 pm »
They key to cutting plexi is a router.  Honestly, with a router its so easy you will be shocked.
Last Project
Epyx Tutorials:
Tutorials
dieseldogpi
« Reply #2 on: September 01, 2009, 10:59:57 pm »
what about lexan?  I heard that was much easier to work with.  Even when I go to drill holes in plexi, it cracks.
Beretta
« Reply #3 on: September 01, 2009, 11:02:36 pm »
lexan is suppose to be a lot more flexible and easier to work on.. but it also is suppose to scratch easier and cost more..
try using a hole saw on the plexy instead of a twist bit.
also go slow i've heard a lot of people having problems simply from putting to much pressure.. just let the drill do the work and go easy.
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: September 01, 2009, 11:07:36 pm »
plexi/lexan are easy to work with if you have a router.  you dont need a good router, one of those $25 trim routers from harbor freight work perfectly.  there are a few threads on this subject..
http://forum.arcadecontrols.com/index.php?;topic=89334.0
if you look about half way down the first page, i have a post where i showed exactly how i did it and which bits to use.
Epyx
« Reply #5 on: September 01, 2009, 11:40:55 pm »
Think of it as plexi and lexan being two different langues but the router speaks them both. The router will make short work of either one with the right bit.  The cracking really only comes into play with conventional drilling/scoring etc. I usually use a small forstner/spade first then just trim flush the hole afterwards.  That way even if it were to crack a bit you would trim out the crack with the router bit afterwards.
Last Project
Epyx Tutorials:
Tutorials
