Main > Everything Else
thatitalian's house build thread - PICS (and loving the new forum!)
stace:
Mate,
Whilst this forum is great and there is a wealth of knowledge here, do you not think it would be of benefit to go to the AV forums where you can get these answers PDQ.
People here have a love for, and get geeky over everything Arcade. People on the AV forums genuinely pull the end off themselves answering questions like these....
Just my two penneth.
Stace
thatitalian:
Been there, done that. The responses are slow and generally unhelpful on that forum. You do get the odd person who is extremely helpful, but they are few and far between. Plus, I like this forum more :P
stace:
--- Quote from: thatitalian on September 09, 2009, 05:48:27 am ---Been there, done that. The responses are slow and generally unhelpful on that forum. You do get the odd person who is extremely helpful, but they are few and far between. Plus, I like this forum more :P
:) I always find them really helpful.
No worries, was just a suggestion.
Dexter:
--- Quote from: thatitalian on September 08, 2009, 03:32:52 pm ---What cable should I use to connect the plates? Coax? And if so where can I buy some from? More importantly, how do I connect the cable to the phono connectors? If I solder, what part do I use?
Also, will I need to use a splitter to connect the wall plate to the sub? If so, what type? (you can see the back of the sub here: ACOUSTIC ENERGY AEGIS NEO 5.1 SPEAKER PACKAGE - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/3225 for details)
If you're using a standard sub out on your amp to the sub in on the subwoofer, you can strip a standard phono cable at either end and solder the wires to the back of the corresponding wall plate pins. For high level (not recommended) you should use speaker cable. Any OFC cable should give you a clean signal.
For my own setup I'm stripping a pair of 5 meter phono cables and soldering them to a dual phono wall plate. One phono will be the feed from the amp to the sub and the other will be a coaxial digital back to the amp for my squeezebox.
Oh, and you WON'T need splitter. For your 5.1 setup the .1 is the amp channel i.e. single channel so you connect 1 phono cable to the "subwoofer line-in" on that sub. When soldering, solder the inner part of the cable to the centre pin on the connector and the outer part of the cable to the ring/sleeve part of the connector.
thatitalian:
Cheers for that! :cheers: I figured it out in the end. You are right about the inner/outer soldering.
One thing I wanted to ask is actually about aerials. I am having an aerial fitted and I have bought wall plates for the aerial points in the house (3 in total). How do i connect the aerial wires (coax again?) to the wall plates? HERE are the wall plates.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
