Main > Project Announcements
Lowboy: First design, then 1/3 build and finally fullsize!
Ond:
Beautiful shadow and light modelling from Vray, great design, why build it 1/3? Just build it :)
MaMeNnO:
@Ond: Yeah, Vray does a great job here! About the why, I think I've explained that... hint openings post. ::)
MaMeNnO:
I've done a little bit more on the design.
These glass supports for the marquee were after all not the kind I'm going to use. The screws are on the front, so I designed some others with the screws on the top.
The speaker grills I need should be small, because the lower panel of the marquee is only 8 cm wide. The speaker grills are only 6 cm (From www.arcadeshop.de).
A top view of the cabinet so far.
XNIF:
ok so this is about the time you should dismantle you cab and start building a new one!
EightBySix:
It's like I'm reading updates for a real build!
running off now to google v-ray
