Author Topic: Set49Mode.exe now at Clicksgaming.com  (Read 1454 times)
zelony
  • Last login:November 16, 2019, 04:00:12 pm
    • Green Chavez Law Firm
« on: August 27, 2009, 12:39:26 pm »
Thanks to 2600 for sending me a copy of Set49Mode.exe I am now hosting the Zip file at
www.ClicksGaming.com/set49mode.zip
I will leave there permanently for anyone whow needs it.
Thanks.
Jeff Green
Beretta
Re: Set49Mode.exe now at Clicksgaming.com
« Reply #1 on: August 27, 2009, 02:14:26 pm »
sorry but what exactly does this do? i take it has something to do with 49way joysticks but other then that im a bit clueless.
zelony
« Reply #2 on: August 27, 2009, 07:14:36 pm »
Here is a link to info on the program.
http://www.mameworld.info/tigerheli/set49mode/
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #3 on: August 28, 2009, 12:53:19 am »
attached set49mode.zip to this thread.
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #4 on: August 28, 2009, 09:15:08 am »
Not trying to hijack this thread - just wanted to mention that as an alternative to set49mode you can use LEDBlinky to program the GPWiz49 on the fly. True, LEDBlinky's primary purpose is to light up LEDs, but it has a 'No LEDs' mode for users with GPWiz49's or u360's and no LEDs. The one advantage LEDBlinky has over set49mode is it can be configured for any emulator (not just mame). Anyway, I'll shut up now :)
Robots will kill you.
Arcade Addiction
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #5 on: January 07, 2010, 01:39:21 pm »
Good info to know about the LEDBlinky program.  Now if I can only find a GPWiz49!  :(
Also, I uploaded the set49mode.zip file to the BYOAC file repository.  You can download it here:  set49mode.zip
DeLuSioNaL29
