Main > Main Forum
Anyone got a good plan for a cabinet to house a 36" crt?
RyoriNoTetsujin:
LOL. As someone with a 31" Desti in his cab (which had to be scratch-designed around the monitor: quarterheaven.livejournal.com) I cannot recommend a showcase style cab enough! ;D
In the end, a showcase style will save you massive amounts of pain and trouble, not to mention it's a really easy style to scale up or down depending on your needs.
Edit: In other words, DON'T try to do what I did.
DJ_Izumi:
http://www.ricweb.com/webyep-system/daten/5-48-im-Bild1-neu-e-8592.jpg
Something like this, only not light guns and instead a podium type control panel. SEems to be the way to go. You could also thusly seperate it to make it more transportable.
zelony:
Go buy yourself a showcase cab. This is what I did and then put a 36" SVGA monitor in it. Here is a picture of what I bought. The picture is from the KLOV website.
Buy the nicest condition cab you can afford, it will make the conversion to MAME easier.
Dr Zero:
The showcase cabs are pretty cool lots of room and modular, I have this style of Dynamo showcase
D10:
There are some drawings for a 34" Dynamo cab on Jakobuds site. Maybe you can modify it to fit your needs.
http://www.jakobud.com/cabinetPlans.php
