Author Topic: Happy Haul  (Read 2165 times)
endrien
  • Last login:August 08, 2010, 08:33:36 pm
Happy Haul
« on: August 26, 2009, 07:40:42 pm »
Well today I managed to get the following for 50$ :
working hatris cocktail with out of focus monitor(Should easily be fixed)
pretty much new mortal kombat 2 upgrade kit(Board, marquee)
Sega cartridge based system with decathlete
Mystery data east board(Have to test to find out)
Heavy Unit board
2 jamma harnesses
1 key/lock
3 monitor chassis for parts
I'm a pretty happy man
I'll post up a video/pics when I get the cocktail unloaded!
Video:
after a little bit of cleanup on the cocktail:
« Last Edit: August 26, 2009, 10:10:53 pm by endrien »
endrien
Re: Happy Haul
« Reply #1 on: August 26, 2009, 09:09:15 pm »
Video and pics uploaded.
Beretta
Re: Happy Haul
« Reply #2 on: August 26, 2009, 09:40:53 pm »
wow you got all that for 50 bucks total? very nice indeed.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:May 04, 2024, 09:08:32 am
Re: Happy Haul
« Reply #3 on: August 26, 2009, 09:58:35 pm »
Nice haul!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
severdhed
  • RIP Dinosaur Hippo
Re: Happy Haul
« Reply #4 on: August 26, 2009, 10:05:11 pm »
very nice find...makes my $50 gutted donkey kong seem like much less of a good deal
Ummon
  • Trade Count: (+13)
Re: Happy Haul
« Reply #5 on: August 26, 2009, 10:52:52 pm »
Where did you get this, and what city/state are you in?
That cocktail being 2P like that just hollers for a JPAC, or jamma switch board. Perhaps both.
Yo. Chocolate.
Stephen Hawking
endrien
Re: Happy Haul
« Reply #6 on: August 26, 2009, 10:58:56 pm »
You know....It is already jamma.
Finchbyrd
  • Last login:November 08, 2009, 06:03:22 pm
Re: Happy Haul
« Reply #7 on: August 26, 2009, 11:13:14 pm »
Very nice. As long as you have the back open, unscrew the nut that holds the lock in and get it out, or use a screw driver on the back of the lock and unscrew the bolt holding the lock arm in, run to home depot and buy you a caster lock, 5/8" probably
endrien
Re: Happy Haul
« Reply #8 on: August 26, 2009, 11:16:04 pm »
I have the back and coin door locks working fine. I don't have the key to the coin area on the bottom though....
bkenobi
Re: Happy Haul
« Reply #9 on: August 26, 2009, 11:36:20 pm »
Just drill the lock.  If you don't have the key, it's useless anyway.  That's how you get a standard lock open, so I assume you can do the same for a barrel lock mechanism.
endrien
Re: Happy Haul
« Reply #10 on: August 27, 2009, 12:44:30 am »
Alright, I'll do that tomorrow when it isn't so early in the morning.
Finchbyrd
Re: Happy Haul
« Reply #11 on: August 27, 2009, 01:07:49 am »
I had to drill all 3 locks on my stand-up cab, its a pain. I broke a few bits because I was rushing, if its standard keyholes then go for drilling them out, just take your time and it'll work. Once you bore the keyhole open you're then drilling into the screws tip.
endrien
Re: Happy Haul
« Reply #12 on: August 27, 2009, 02:24:48 am »
Mystery Data East board is fighters history
endrien
Re: Happy Haul
« Reply #13 on: August 27, 2009, 01:13:03 pm »
Coin area lock drilled out fine, I'll get a new one next time I'm out.
Shortbus
Re: Happy Haul
« Reply #14 on: September 04, 2009, 11:17:22 am »
I will give you $60 for it, huh? Huh? you'd make $10, not a bad deal...
kidding, great deal man, I'd be all over that in a heartbeat! good luck!
