Author Topic: control panel size  (Read 908 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
control panel size
« on: August 19, 2009, 05:37:32 pm »
I have a CP that is 12 tall by 24 wide is there going to be enough room for say 2 players with 6 buttons each and a track ball
Best of the Best of the Best. Sir!
drpcken
  • Last login:January 19, 2012, 08:39:15 pm
Re: control panel size
« Reply #1 on: August 19, 2009, 05:48:27 pm »
Download Google Sketchup (it's free) and play with the dimensions.  Also you could use some scrap wood to make a mock up.  Or better yet get a large piece of cardboard cut with your dimensions to give you an idea.
Good luck!
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
« Reply #2 on: August 19, 2009, 06:12:22 pm »
Here's my thread where I'm working on a similar problem:
http://forum.arcadecontrols.com/index.php?topic=94330.0;all
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
DaveMMR
    • TeeVee Games
« Reply #3 on: August 19, 2009, 06:41:00 pm »
This has been addressed fairly recently so be sure to do a quick search for more answers.  I think the consensus was yes, but be a little smart with the spacing.  My panel is 25" wide with the same setup (two players, 6-buttons, 3 inch trackball.   I made sure my joystick plates were vertical, I stuck my buttons as close to the plate as possible and I even let a button bezel overlap the trackball plate (you don't see the plate if you recess it).
But YMMV - Sketch it up and play around.
Vebbo
    • Overaged Lucky Drivers
« Reply #4 on: August 19, 2009, 06:46:58 pm »
Here's my attempt on squeezing in 2 joys, a trackball and a spinner, haven't had much time lately to continue on my project as i wished, (4 kids, working overtime blah blah blah). The overlay is 26.66 inch wide thou.
http://forum.arcadecontrols.com/index.php?topic=94847.0
Vebbo
Epyx
  • "You're an oddity"
« Reply #5 on: August 19, 2009, 07:25:25 pm »
Imo 24-26" is fine as long as the P1/P2 control are as far to the left and right on the CP as they can be...ie even without a trackball in the middle space them apart.
Last Project
Epyx Tutorials:
Tutorials
