Arcade Collecting > Restorations & repair
SkeeBall Help
<< < (3/3)
Kevin Mullins:
Here's a pic from UncleT of his machine I snagged that shows the digit piece pretty well.
(and my poor example of the bulb layout)
It's more or less just a plastic "box" that fits over each individual light bulb with cutouts to mimic the segments of an LED display and then that whole piece has a piece of red acrylic of sorts to cover those segments so that they show as red "segments".
I believe UnclkeT's machine is a Model H Skeeball..... the Model S Skeeballs aren't much different.
RichSorr:
You can use a piece of red acrylic or red litho tape. litho tape is what skee ball uses on a lot of their displays. Finding it wide enough can be tough though.
coyote640:
Thanks to everyone.....
Kevin, here is a pic with the measurements.....
And a pic of the boards.... to help see what I have and to figure out what the dip switch setting are.
I will also pull the re-seat everything and check stuff over to see what the reset problem is.
Kevin Mullins:
--- Quote from: coyote640 on August 23, 2009, 02:18:07 pm ---Kevin, here is a pic with the measurements.....
Cool... I'll try to measure a regular Skeeball version up as soon as I can get ahold of one.
(didn't get down to location yet)
coyote640:
Thanks alot.... this is much appreciated.
On the CPU it says FAB 002 and there is a sticker on one of the chips "FAB U3 1pt 11/15/04. A sticker on the back reads: "F.A.B. Electronics Co., Inc. Pleasantville, NY 10570 (914) 769-5104
Navigation
[0] Message Index
[*] Previous page
Go to full version
