Author Topic: DK - did you know....  (Read 1991 times)
Ummon
  • Trade Count: (+13)
« on: August 18, 2009, 08:38:14 pm »
The second time on girders, you know how some people wait for the barrel and jump it, or wait until it almost hits them in the back and then jump and you get 100 points for proximity?
Well, what about the first blue barrel? I doubt it's original, but I don't recall seeing anyone doing it or talking about it, and so I tried it. It's not easy, actually. There's a special timing required, where you go behind the oil furnace, and right when the barrel hits the girder just above you, you run and jump, and clear it!
It has to be right, cos obviously due to how the game handles collision detection in that part of the screen, you don't even have to touch the barrel to die.
Try it out.
Yo. Chocolate.
Stephen Hawking
  • Last login:May 06, 2024, 04:31:28 pm
Re: DK - did you know....
« Reply #1 on: August 19, 2009, 12:13:36 am »
I will try it out - anything to improve my pathetic score!
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #2 on: August 19, 2009, 08:56:21 am »
If you watch videos/MAME INPs of some of the higher scoring players, they wait for the blue barrel to drop, jump next to it, then jump ahead of the spawned fireball to get several hundred points while they wait for barrels to get near the bottom. Most of them use the bottom hammer to point press too.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: August 19, 2009, 09:21:54 am »
This is what I do. Learned it from Scott Kessler.
Ummon
« Reply #4 on: August 20, 2009, 08:51:04 pm »
I'm not sure I understand that one, and will have to look for it.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #5 on: August 22, 2009, 10:50:14 pm »
Ohhh. You mean, both jump points' are awarded by proximity. Yeah, hadn't thought of that. Actually, I can't see the time it takes for that to really increase score. At best, it might match what you'd lose on the timer?
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #6 on: August 23, 2009, 01:51:41 am »
Okay, I tried this. I couldn't get the barrel jump, but got the fireball one.
Yo. Chocolate.
Stephen Hawking
CrazyKongFan
« Reply #7 on: August 23, 2009, 09:59:22 am »
Kong releases <timer/100>+1 barrels, so there's 51 barrels total on level 1 (timer starts at 5000). Any extra points you can get on top of jumping over every barrel adds up. If you can get the barrels doubled up and jump them (for 300 or 500), and run down the ladder and jump them again, yuo can really gain some ground. You can also jump the ahead of fireball at the bottom (already mentioned), but if you can time it to get a barrel in that jump, that'll give you 300. That's how the guys get so much extra points. The MAME record right now is 12,800! (I sometimes don't even have that at the end of the rivet level ;D )
Ummon
« Reply #8 on: August 24, 2009, 07:38:33 pm »
I've gotten 800 from jumping three barrels, or from being in a really odd and tight spot where I jumped a couple, and had my back to a ladder and barrel came down it at the same time, or was moving and just missed getting bonked by it coming down.
I've nowhere near the level of interest that I'd explore all this kind of point-press, though.
Yo. Chocolate.
Stephen Hawking
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
« Reply #9 on: August 24, 2009, 08:50:10 pm »
Wow, and here I thought I was doing pretty well getting 9500 sometimes.
Oh well...
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
CrazyKongFan
« Reply #10 on: August 25, 2009, 09:20:26 am »
I've gotten 800 from jumping three barrels.
FYI: You actually only got 500, even though it says 800...a known DK bug ;)
Ummon
« Reply #11 on: August 26, 2009, 09:13:05 pm »
I remember reading Hodges article on that...or maybe it was something over at Jeff's rom hack. Either way, I don't remember. I know I get 800 from hitting an oil barrel with a hammer when it says 800.
Yo. Chocolate.
Stephen Hawking
CrazyKongFan
« Reply #12 on: August 27, 2009, 10:24:32 am »
Yeah, it's just the jumping that has the bug, not the hammer smashes. Crazy Kong also has a similar bug when jumping over 3+, although instead of showing 800, it just shows garbage.
Ummon
« Reply #13 on: August 28, 2009, 11:11:51 pm »
I've never really liked CK....but I may give it a run.
Yo. Chocolate.
Stephen Hawking
