Author Topic: Average width/height of an arcade cab?  (Read 13815 times)
endrien
  • Last login:August 08, 2010, 08:33:36 pm
« on: August 18, 2009, 07:34:13 pm »
I'm looking to see if I have enough space in my spare room. Whats the average width and height?
severdhed
  • RIP Dinosaur Hippo
Re: Average width/height of an arcade cab?
« Reply #1 on: August 18, 2009, 07:54:40 pm »
that can vary greatly, depending on the cabinet.  most are around 6ft tall...
mine is on the small side, since it was designed for a 19inch monitor, it is just under 25 inches wide, my control panel is detachable and is 30 inches wide.
  • Last login:Today at 08:24:26 am
« Reply #2 on: August 18, 2009, 08:28:38 pm »
average.. I'd say between 26 and 34 inches wide, and about 36 inches deep, 70 inches tall.
needless to say my Mortal Kombat II is much bigger then my Namco Cyberlead
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: August 18, 2009, 08:48:32 pm »
Assume 3 feet by 3 feet by 6 feet. If a fridge box will fit, your average arcade machine will fit.
If those measurements are close, then you need to be specific about the cab.
Working: Not Enough
Projects: Too Many
Progress: None
endrien
« Reply #4 on: August 18, 2009, 08:50:24 pm »
It's close to 4 feet wide where I'd put the cab. Gotta look to see what my options are cab wise tomorrow.
miles2912
« Reply #5 on: August 18, 2009, 10:08:17 pm »
... and this brings up the FIRST rule of arcade cabs.  Measure the doors width before you buy and or make a cab.
endrien
« Reply #6 on: August 18, 2009, 11:12:40 pm »
If I can't fit it in my spare room I can just put it in my garage. I would just prefer it go in my spare room though :P
Beretta
« Reply #7 on: August 19, 2009, 03:45:38 am »
another rule, messure the longest spot on teh cab..
IE say top front (usually by marquee and highest spot on cab)
to bottom rear
the reason to do this is if you have low ceilings you need to know if you can clear them.. say if you're moving the cab with a dolly, you'll have to tip the cab upright.. where i live actually has low ceilings.. like 6.5 feet, i have'nt had a problem yet but pretty close, closer then you'ed think.
i agree with the 3x3x6 assessment, thats pretty good measurement to keep in mind for general use.
most cabs will be less then 36 inches side, as thats the most common width door way.
