Main > Project Announcements
First time not allways the charm
xerox4100:
http://www.happcontrols.com/amusement/acesor/49100000.htm
have any of you tried this?
Beretta:
never heard of a jamb saw but i have heard of a flush cut saw.. if im not mistaken those are the saws where the blade is on teh very end.. sort of like a rotary tool with a cut off wheel is.
a circular saw would have it's guide and guard keeping it from going tight up against a flat surface.
xerox4100:
I understand not, maby I shuld watch some bob vila shows to get some wood tool guidance
xerox4100:
I went out and bought the monitor for my cab today. I currently have it hooked up to my laptop and cant believe how good this looks, launched hyperspin today and WOW it looks amazing,
Monitor type
23"diagonal idescreen Thin Film Transistor LCD active matrix
Native Resolution
1920 x 1080 @ 60 Hz (recommended)
Contrast Ratio
1000:1 (typical) 3000:1 (dynamic)
Brightness
300 nits (typical)
Pixel pitch
0.265mm
Response rate
5 ms (on-off) (typical)
Sound
Integrated speakers, 2W per channel
ENERGY STAR Qualified
Yes
Signal Input Connector
VGA and HDMI; Analog: 15-pin miniature D-sub (VGA cable included); HDMI: Version 1.3 (HDMI cable not included); NDCP
Tilt
+25 to -5 degrees
Detachable base (for mounting)
Yes
Dimensions
22.2" (w) x 16.3" (h) x 7.6"(d)
xerox4100:
Cyborg Keyboard
High-end, adjustable, gaming keyboard with customisable backlighting,
programmable functions and media keys.
* Multi-colour backlighting with Tru Vu illumination through keys (mix shades from Red through Amber to Green) and adjustable brightness
* Touch-sensitive, backlit dashboard control panel
* WASD, cursor, ‘Cyborg’ and NumPad keys can be lit independently from the rest of keyboard to highlight commonly used gaming keys
* Cyborg Mode – instantly disable the Windows keys and configure the colour and brightness of your gaming keys at the touch of a button
* Set and forget – persistent key illumination settings ensure colours remain even after a system reboot
* 12 programmable ‘Cyborg’ keys
* Hard wearing, metal-plated key caps in key gaming areas
* Pass-through USB, audio and microphone sockets
* Enhanced multiple key presses in gaming areas for complex in-game commands
* Adjustable wrist rest and keyboard rake angle (front and back)
* Gold-plated connectors for USB and Audio
Navigation
[0] Message Index
[*] Previous page
Go to full version
