Main > Main Forum
XBOX 360 analog controller hack... could use some help from you all
Pages: << < (4/4)
Bender:
or is there a way to make a 100k joystick send a 10k signal, other than replacing the pots?
please excuse my ignorance, like I said I'm new to the electrical side of things
HaRuMaN:
--- Quote from: Bender on August 11, 2009, 12:41:32 pm ---or is there a way to make a 100k joystick send a 10k signal, other than replacing the pots?
Yes.  If you add resistors in parallel, they add like this:
So.  Adding a 11,111 ohm (11.111k ohm) resistor in parallel will give you a 10k ohm (combined) resistor.
Spectrum:
You may have already seen this but I'll throw it ought there anyway.
http://forums.xbox-scene.com/index.php?showtopic=618909&st=15
The 4th post down has the relevant portions of the PCB traced out for a wireless XB360 Controller
RyoriNoTetsujin:
Has anything more come of this thread?  Perhaps in a build thread I'm not familiar with?
I'm interested in potentially building/comissioning an analog-inclusive interface for PC/PS3. (For the usual fighters, MAME etc., but also for Williams Pinball Hall of Fame, which has tilt functions and the ball launcher mapped to the PS3's analog sticks -- with no way to change it in software.)
Did anyone source the Quasimodo analog sticks or something similar?  (WOW Quasimodo designs are incredibly ugly, by the way. Functional, which I appreciate, but UGH-leeee.)
Namco? HarumaN? Bender? I know you guys are up to something!  ;D
RyoriNoTetsujin:
Well now that I've had some time to do a little research/shopping, I'm going to add these couple of links (if for no other reason than so I don't forget them!)
Analog thumbsticks (with 10k pots) a la PS2/PS3:
http://www.seeedstudio.com/depot/electronic-brick-playstation2-analog-joystickanalog-p-468.html
and a cheaper option (with what looks to be a nicer breakout board below it):
http://www.sparkfun.com/commerce/product_info.php?products_id=9032
Pages: << < (4/4)
Go to full version
