Main > Everything Else
I'm in trouble
<< < (2/3) > >>
SirPeale:
Same.
Kevin Mullins:
Now go to your room.
Why not find the driver for your network card off the internet ?
Instead of waiting to buy a new card.
Franco B:
--- Quote from: pinballjim on August 09, 2009, 11:51:35 am ---Yeah, here I was about to bust out my "don't answer any more of the police questions" or "she can't force you to take a paternity test if you leave the state, nice knowing you" routines.
  :P
Thats EXACTLY what I was thinking. Oh god, thats bad isn't it  :laugh:
SavannahLion:
To begin with, stop using Windows. It's a despicable OS that pokes around on hard drives when the drive is in no state to be poked around with.
That said, you have two choices. I think a tool like TestDisk might work for you. Based on the tool description, it seems to be the correct one. I have copies of the tool with Slax, Knoppix, and UBCD so it's readily available and easy to find. I've never personally used it, my HDD problems are usually a lot larger than just a lost artition table. Give it a shot.
Alternatively, you can do what I'm doing right now with a drive and blindly pull the entire drive data into a seperatedrive so you can work with it properly. The process is ugly and takes some real work. Not really for the faint of heart. DD and variants are the key to that. In your case, I would use it as a last ditch effort. Don't use the "intelligent" processors like CloneZilla (unless it has TestDisk, I'm not sure), it probably won't do what you want.
DaveMMR:
Is it too late for me to say "same"?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
