Author Topic: is this a bootleg?  (Read 1033 times)
jackspicer
  • Last login:January 28, 2010, 07:47:54 pm
is this a bootleg?
« on: August 05, 2009, 03:05:50 pm »
I picked up another galaga pcb but it has 36 pins does that mean its a bootleg? and does anyone know if it plays like the original one?
AND RIGHT HERE THERES SOMETHING MISSING?
Kevin Mullins
    • Me on Myspace
Re: is this a bootleg?
« Reply #1 on: August 05, 2009, 03:09:07 pm »
Any manufacturers markings or numbers silkscreened on the pcb ?
No = bootleg.
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #2 on: August 05, 2009, 03:09:41 pm »
Looks like you're missing a cap, 100 microfarad.  Just like the ones above it.
Beretta
« Reply #3 on: August 05, 2009, 03:12:32 pm »
i do not know if that is a bootleg..
it certinly looks like one, with the chips spaced out so far, but i dont know what the original board looked like..
also those jumper wires are very interesting i would'nt expect to see them on an original.
look on the board for some markings if it has no markings (PRINTED) not sticker then i would be suspect of it.
as for game play should play ok if the hardware matches up the boot leg is just a hacked & ripped off rom set.
although i know from reading that game was ran on several different hardware those might have been changed more then just it's protection, i would imagine would still play close if not the same..
if it does'nt play the same in the arcade who would play it? the op would'nt make much money if it ran choppy or something.
jackspicer
« Reply #4 on: August 05, 2009, 03:17:55 pm »
No i dont see any markings or anything, why do you think that the cap was cut? should i replace it? And i just found this on mikes arcade http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=Galaga36.txt
Kevin Mullins
    • Me on Myspace
« Reply #5 on: August 05, 2009, 03:18:06 pm »
Both those things are quite common of boards this era.  ;)
Tighe
  • Last login:May 04, 2023, 10:19:57 pm
« Reply #6 on: August 05, 2009, 03:19:08 pm »
Doesn't look anything like my galaga.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: August 05, 2009, 03:47:56 pm »
Info on Galaga and a number of boots:
http://www.arcadeshop.com/galaga/galaga.htm
Working: Not Enough
Projects: Too Many
Progress: None
jackspicer
« Reply #8 on: August 05, 2009, 04:06:52 pm »
wow he doesn't have a board like mine on there at all :lol well my hakko iron should be in tomorrow so i'll get to work on a jamma adapter. I got this from a friend for 10$ but he didnt know anything about it or if it even works.
CheffoJeffo
« Reply #9 on: August 05, 2009, 04:15:19 pm »
There is mention of a 36-pin boot over in the coipop.org pinout sections:
http://www.coinop.org/kb_dl.aspx/KB/gametech/galaga%20tech.html
Do you have a pinout for it ?
Working: Not Enough
Projects: Too Many
Progress: None
jackspicer
« Reply #10 on: August 05, 2009, 04:21:49 pm »
ya, the one you just posted... But before i hook it up should i solder on a 100 microfarad cap where it looks like one was cut off, because i know i have one around here somewhere
