Main > Main Forum
any trick to crimping wires into a disconnect
<< < (2/2)
SirPeale:
--- Quote from: OSCAR on July 10, 2003, 11:10:02 pm ---The only real trick is to make sure you have the right size disconnect for the wire you are using.  Using a blue disconnect on 22ga wire wire make for a sloppy connection that won't hold well.
I've used 22G wire with the blue ended connectors, and have had no problems whatsoever.  I've even given them the 'tug' test.
Previously, I had tried doing this with just a pair of pliers, with less than great results.  Ever since I started using a 'real' crimper (which came with a box of connectors I bought years ago) I've never had a problem.  I actually only started using the crimper just a little while ago, due to being really stiff.  A little WD-40 fixed that.
OSCAR:
--- Quote from: Peale on July 11, 2003, 08:59:40 am ---
The size of the barrel on disconnects varies a bit by manufacturer, I've noticed.  Since you had good luck with 16-14ga disconnects on 22ga wire, then I imagine that is more of the exception rather than the rule.  The manufacturer has recommended wire sizes for a reason, I suppose.  :)
SirPeale:
--- Quote from: OSCAR on July 11, 2003, 10:55:22 am ---The size of the barrel on disconnects varies a bit by manufacturer, I've noticed.  Since you had good luck with 16-14ga disconnects on 22ga wire, then I imagine that is more of the exception rather than the rule.  The manufacturer has recommended wire sizes for a reason, I suppose.  :)
That, and I squash the $#!7 out of it, just to be sure.
Wade:
Let's not forget that crimp connectors should only be used with stranded wire! Solid wire won't work reliably, don't bother with it.
Wade
dhansen:
Check out this thread...
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=6944;start=msg58551#msg58551
Navigation
Message Index
Previous page
Go to full version
