Author Topic: No Sound on My Sega New Astro City  (Read 4115 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: July 27, 2009, 01:50:20 pm »
Well, I'm making progress on this cab now. Concluded the monitor is dead but this shouldn't be a problem as I have at least one spare monitor I can replace it with. However, I'd like to get the sound sorted so that I can at least conclude that everything else is okay.
I've carried out lots of multimeter tests - PSU , 5, 12. etc and they were all okay. In reference to the photo I have taken below... I have connected the speakers to the Sound Out and they are humming, so clearly the amp and speakers are working, however, what do I connect to the Sound In socket, if anything? It seems logical to me that would be the sound from the board but I can't find any type of cable to connect into the socket - please could someone help!
Also, if someone could also help me with telling me what each of these sockets are (pictured below), that would also help me... So far I have concluded (going from left to right)
1. Something to do with speakers?!
2. Player 1 controls?
3. Player 2 controls?
4. Credit counter!?
5. Ground
Sorry for being a total 'noob' (hate that term!) but if anyone could help a king one, then I'd be really grateful!
« Last Edit: July 27, 2009, 02:21:17 pm by slapaham »
Kevin Mullins
    • Me on Myspace
Re: No Sound on My Sega New Astro City
« Reply #1 on: July 27, 2009, 02:36:22 pm »
See if this helps:
http://bonbaiserdecapo.free.fr/temp/doc%20astro.pdf
There are schematics and a wire color code chart on the last few pages.
slapaham
« Reply #2 on: July 27, 2009, 02:56:12 pm »
Thanks Kevin.
I always find the wiring diagrams a mess to follow. I followed the speaker wires from my Jamma harness but the inside of an Astro is a nightmare!!
I'll take a long, hard look at the diagram and hopefully figure it out.
slapaham
« Reply #3 on: July 27, 2009, 03:22:52 pm »
Right, I've made progress on this - I have sound! But it is soooooooo quiet, you have to have your ear shoved right against the speaker to hear anything! What can I do to sort this problem out?
Thanks guys! :)
  • Last login:Today at 08:24:26 am
« Reply #4 on: July 28, 2009, 09:39:44 am »
amp, volume pot, sound setting on board?
what game are you running, and is there a volume control menu/pot for it?  for example, NBA Jam requires an external pot, MKII has volume control in the operator menu and Tekken 2 has a pot built into the board.
slapaham
« Reply #5 on: July 28, 2009, 04:28:20 pm »
Hi chap
Well, as far as I'm aware, you don't actually need to use the sound amp on Jamma PCBs. I think the amp is there for other formats such as STV, etc which require an external amp (although I could be wrong on this!)
Anyway, sound kicked in completely randomly so I'm assuming there may be a loose connection somewhere - I'm hoping nothing too serious!
Thanks for the feedback, appreciate it! :cheers:
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #6 on: July 28, 2009, 04:43:32 pm »
The culprit for this is usually the pot.
slapaham
« Reply #7 on: July 29, 2009, 05:55:24 am »
Are they easy enough to replace/sort? Also, is it a pricey procedure? :P
Cheers for the help
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 05:41:28 pm
« Reply #8 on: July 29, 2009, 06:33:11 am »
Fiddle with the volume pot before you go and replace it - if the sound is scratchy and comes/goes suddenly as you adjust the pot, then replace it. They are very cheap & easy to replace.
slapaham
« Reply #9 on: July 29, 2009, 11:13:18 am »
Ah, that's reassuring, cheers Zebidee! :)
