Author Topic: Best way to test a CRT monitor?  (Read 1317 times)
heemid
  • Last login:December 04, 2015, 01:02:18 pm
« on: July 27, 2009, 09:18:29 am »
There is a local guy that has ~25 PVM-2950Q, he said they have VGA input through BNC, will these even work well for an arcade?
I was going to bring my laptop, test them and get a few. Whats the best/easiest/fastest way to check them? I was thinking just a NTSC test pattern. Thanks.
« Last Edit: July 27, 2009, 09:41:38 am by heemid »
heemid
Re: Best way to test a CRT monitor?
« Reply #1 on: July 27, 2009, 09:35:27 am »
Some Pics I pulled from an Ebay listing
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
« Reply #2 on: July 28, 2009, 06:42:33 pm »
have you ever noticed how their are 6 wires coming off of jamma monitors and boards?
R, G, B, 2 sync pins, and Ground?
your line 3 set of connections on this monitor are for seperate y g b sync connections.
sounds to me like you need to order a bnc breakout cable from Cables to go or digikey.
and yes i believe you could use this with an ArcadeVGA provided you had the arcade VGA breakout as well as the BNC breakout. simply a matter of matching up the colors i believe.
Andy?
mvsfan
« Reply #3 on: July 28, 2009, 06:43:44 pm »
as far as testing the thing, just bring your supergun with you.
mvsfan
« Reply #4 on: July 28, 2009, 06:46:49 pm »
oh yeah, forgot this. You need to hook up the bnc breakout to your supergun's video.
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
« Reply #5 on: July 29, 2009, 08:05:05 pm »
These make excellent arcade monitors.  You will need a VGA to RGBHV cable and soft15khz installed on your computer.  From there on I recommend you use Nokia monitor test to test the convergence, color, and geometry of the monitor.
If you want to use your laptop I recommend burning a test DVD and using the S-video input on the monitor to check the image quality.
