Main > Everything Else
PC shutting down randomly *sigh*
<< < (2/3) > >>
Dr Zero:
--- Quote from: hulkster on July 25, 2009, 04:24:15 pm ---in case anyone is reading, that "Temp1" reading has gone up to 61C since i posted the screenshot originally.  :-\
Here this might help with what temp is ok
http://www.technibble.com/what-is-my-computers-maximum-cpu-temperature/
Edgedamage:
Check the power connector on the motherboard I had a system that kept shutting off out of the blue. When I went to try a different PSU I noticed the 12+V pins on the connector were brownish black.
daywane:
I only see 1 reading of a fan.
That must be the CPU fan
Try new thermal grease. first
since you are there also check the legs on your CPU fan.
make sure there not broke.
I do not know what CPU you have but socket 478 seems to break often
richms:
That's not that hot.
IME its usually PSU instability - either the power supply or the regulators on the board has shot caps as already mentioned.
Hang another PSU on it and see how it goes for a while.
Dartful Dodger:
--- Quote from: hulkster on July 25, 2009, 08:43:08 am ---ive got a home theater PC running windows media center and its been working fine for a while, but now all of a sudden it just starts shutting down at random times.
SO....suggestions?
Stop watching that Erin Andrews' video and update your virus protection program.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
